Question about Whirlpool Dishwashers
Ikea dishwasher it is a built in plastic giant tub model w10254949b. the top rack gradually cleaned less and less, and now is basically useless. water is probably not getting up there, and sprayers are not turning. Is there an easy solution to this?
  • 108 Answers
SOURCE: I have an Inglis Soundblock II Dishwasher. The
It could be that the machine isn't filling properly with water- which could be a faulty or clogged water inlet valve. I'm not quite familiar with Inglis, but if you still have the manual, check and see if there is a way to adjust the amount of time the water valve stays open at the beginning of the cycle.
Or just add a liter or so of water at the beginning of a cycle and see if that helps- but make sure you add it after you hear the soap dispenser open- the beginning of most wash cycles is a quick rinse cycle, so any water you add will only be in there for a couple minutes before the machine drains and attempts to refill.
Posted on Jul 30, 2009
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
  • 26 Answers
SOURCE: Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Posted on Sep 27, 2009
SOURCE: DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Posted on Nov 15, 2009
  • 5 Answers
SOURCE: Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Posted on Dec 03, 2009
Water still in machine
Check for restrictions in the motor, Pull the drawer all the way out, fold the side racks out of the way and lift the wire basket out of the tub.
Lift the wash arm off
Then twist the plastic ring and the lower metal plate will lift out.
Grab the motor and twist anti-clockwise and pull up to remove, Check for anything stuck under there and look for any damage to the plastic on the tub or impeller.
If the impeller is damaged you can either put up with it as it is or replace the impeller.
e-assembly is just a matter of doing it all but backwards.
Mar 07, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Kitchen aid tall tub dishwasher model #KUDCO3IVWH Yesterday the top rack didn't clean, today both racks stayed dirty - took apart the food chopper assemble and notice that there is water in the...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2010 | Kenmore 16372 / 16374 / 16379 Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Top rack dishes not getting clean
When the dishes on the top rack are not getting clean the most common problem is that the water supply hose in the rear of the top rack is misaligned. With the rack empty, pull out the rack and look in the rear where the supply hose slides into the water supply. Often a plastic clip or two has come apart. Realign everything and it will work fine. If you need a diagram go to sears direct parts where they have an excellent website. Enter your model number and you will be able to see a schematic showing each part and how they go together. Joe
please rate my answer as very helpful. thank you.
Apr 04, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Water level/dirty dishes and traps
sounds like the drain pump is not doing its job to recycle the water and allow for replemish of fresh water for the rest of the cycles,try looking closely at pump out system and monitior how fast it disposes of water hope this helps
May 27, 2009 | Kenmore 15121 Built-in Dishwasher
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
