Question about Oreck Magnesium Upright Vacuum Cleaner
Clogged head I have stuffed mouse stuck in "elbow" of the vacuum head. I pulled the bag off but still can't reach it. How do I get inside to unclog?
    Problem Solver:
  • 18 Answers
You can try a sink drain flexible wire cleaner. if this will work for you then simply turn/twist it till it gets to the location and hook the object with the end of it. that should work...hopefully
Posted on Nov 22, 2013
Can't open vacuum bag compartment
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Nov 10, 2014 | Electrolux Aerus Lux Guardian 9000...
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
Why does my panasonic MCUG415 hose stop working after bag change?
The replacement bag may not be installed correctly or something in the suction path is being disturbed by the process (maybe a "bag full" detector). In an upright, there is a shutter that directs suction to the floor or the hose and it may be getting confused.
Apr 26, 2017 | Panasonic Mcug415 Upright Vacuum Cleaner
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
Honeywell 703 central vacuum seems very hot after using
David
I recently purchased the same unit and had the same issue. I have since received a replacement and realized where the problem was for me. when Honeywell packages the unit for shipment they place all the extra parts including the muffler inside the canister. If the box is inverted in the shipping process than all those items create pressure on the filter/bag that seals the dirt canister from the suction side of the motor. In my case the bag was damaged/torn from the items inside during shipment and I didn't realize it. The motor then sucks a lot of hair, dirt and debris into it's cooling blades causing extra load when it turns. In my case it was extreme enough excess load that it overheated the brushes and covered everything in black soot. So...if it runs hot i suggest you inspect the bag/filter for holes. best of luck ..it worked for me
Aug 28, 2013 | Honeywell 4B-H703 Central Vacuum Power...
Need to clean roller on classic
Unplug, cut hair on rollers and pull to clean. Remove dust bag and use a bent hanger to pull out the clog from the intake tube, most likely there is paper caught in the hair.
Dec 04, 2012 | Dirt Devil M0100 Classic Hand Vac
Indicator red light
i had a similar problem with my pro. the wires would get a heavy white build up that would not come off with the wire cleaner so i had to take the unit apart and clean the wires by hand and that worked for me. you may be able to reach them if you put a Q-tip in the end of a straw.
Jul 16, 2008 | Air Purifiers
Oreck Magnesium Upright Vacuum Cleaner Logo
125 people viewed this question
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
