Question about Maytag MGRH865QDB Gas Range
How to turn on my oven model mgrh865qds - Maytag MGRH865QDB Gas Range
    Genius:
  • 1,198 Answers
Gas controls are usually push and turn. The pilot has to be lit and the thermocouple warmed up before the gas will come to the oven. If the pilot is lit for a while and gets a little bigger when you turn on the control, but the oven doesn't come on, the thermocouple is bad. Hopefully it's not built into the control, because they are real expensive.
Posted on Nov 22, 2013
Top oven will not turn on
Make and Model of the oven in question?
Apr 14, 2017 | Ovens
Oven timer
What make and model oven?
Jul 17, 2013 | Ovens
OVen display is blank and oven won't turn on. Oven has power (checked breaker, oven light works)
Can you supply a model number?
Most likley you have a bad erc control board ( clock). But a model number would help narrow it down.
Jan 02, 2011 | Whirlpool RBD275PD Electric Double Oven
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
If i turn on the oven the pilot burns but no gas
This is a bad gas valve. You will need your model number off this unit to order the correct part. If you will look around the front frame of the oven, there is a serial plate with model number on it. If it has a bottom drawer, it may be on the front frame when you open the drawer. Give us a call with your model number and we'll get the right part out to you asap. 972-859-0929 - We look forward to working with you! Hope this helps!
Oct 03, 2009 | Ovens
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
START AND RUN PROBLEM
check the motor relay. there are 4 wires( 2 are pink and black) this goes to the coil of the relay and must show resistance(closed) you can also jump out the 2 blue wires and see it the unit keeps running. The part number for the relay is: FSP3405281 approx 40.00US
Feb 28, 2009 | Dryers
Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Mar 15, 2008 | Kitchen Ranges
Maytag MGRH865QDB Gas Range Logo
59 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
