Question about Panasonic Heating & Cooling
My rinnai 556f energysaver heater filter and on button blink red, the digital thermostat stays on 68 degrees and will not go hotter or cooler.. i do have natural gas going to it and it is on.. i cleaned out 1 of the hoses in the back that i had easy access to, but the unit blower still just starts up then shuts down.
  • Robert Jacobs Nov 22, 2013
    thank you.. the unit does not lite up or even attempt to spark.. I will be away for 2 weeks.. I have the tenant using his back up electric heat till I rturn.. im guessing the bad thermostat makes the most sense right about now, but I am open to many more suggestions on troubleshooting.. Thank you!!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Hello, that could be two problems, first could be the gas sensor that cuts the power when there is a leek , second could be the thermostat faulty.
Thanks
Posted on Nov 22, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Posted on Nov 26, 2007
  • 33 Answers
SOURCE: rinnai energysaver 1000ft wont stay on
Check your gas supply is it turn on ?
Posted on Jan 16, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Rinnai heating system 556F that shut off
This unit has a diagnostic error code recorder. To play back your error codes, with the unit off, push the up arrow, down arrow and economy button all at the same time and hold for 3 seconds. Record each number that lights up. In your owners manual or on rinnai.us there is a error code guide that may help. Or post the error codes on Fixya and I can give you some pointers.
Posted on Jan 28, 2010
  • 120 Answers
SOURCE: rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Posted on Aug 01, 2010
rockmeister
  • 2047 Answers
SOURCE: Our Rinnai Energysaver 1001FT Heater starts and
Heaters are a bit tricky to deal with as fixing them are better left for experts. When the heater shuts down on its own it usually is as a result of over heating in the heaters system. If the unit in the heater which is meant to regulate the unit temperature happens to be faulty the guage records a higher temperature than is in the unit and this triggers a close down of the unit. Get an expert to service it check the termostat and also check the radiator for leakages. Feel free to request further assistance.
Hope this solution has been helpful?
Posted on Sep 08, 2010
Rinnai DV Propain Heater 556F
Sounds like the relay might be going bad and needs to be replaced
Apr 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
I rent and have a Rinnai Energy saver 556F. I have it at 64 and the light blinks for 68. I would like to know why. It is 56 out side now thank you
Shadow,
The 68 you see is an error code. It means you have had an over heat situation. You should be able to clean the filter and fan area and restart. Turn the heater off and on again, that should reset everything and you should be good.
Tom
Oct 06, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai energysaver 556f manual
Jul 27, 2010 | Panasonic Heating & Cooling
I have a Rinnai heating system 556F that shut off by itself and the lights start blinking. when I start it again it will start right away but it won't last long till it shut off again (1.5 hours). any...
Jan 27, 2010 | Honeywell Heating & Cooling
My tank says I have 32 gallons left but the heater won't work (rinnai 556f). It turns on for about 15 seconds and the light on the power button turns red and starts blinking. What does this mean?
If you hold down the economy button and the up and down arrow buttons for 5 seconds the unit will start an error code display. Get a helper and yell out the numbers when they start blinking. Post the error codes and we can help you
Dec 23, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Jan 24, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
I have a Rinnai Energysaver 556F
The heater will have some error codes stored in it. To retrieve them get an assistant to write down the codes as you see them. They come quickly. OK to get the codes, push down on the Economy button and the up arrow and down arrow at the same time. Hold for three seconds. It will take three fingers to do this. Once you get the error codes, look in your owners manual to diagnose.
Nov 21, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Nov 10, 2007 | Rinnai EnergySaver 556 Air Conditioner
Heating & Cooling Logo
143 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
