Question about Toro Power Clear 418 ZR - Single Stage Snow Blower - Recoil
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
Trouble shooting new toro power clear 418 zr - slightly misses and pops while running.
    Master:
  • 755 Answers
When you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Posted on Jan 20, 2015
Electric start does not work. how do i trouble shoot it?
Mine the electric cord had pulled out of the receptacle.on the blower so it was not working. I pulled it right out and reinstalled it It's ok now.
Do you have power coming to the blower or have you blown a GFI and it needs to be reset. Does the starter click or try to work? These are things that I have to know before we tear things apart.
If it buzzes it could need a gear replacement. on the starter itself.
Mar 03, 2015 | Toro Power Clear 418 ZE - Single Stage...
Snowblower won't start
"Gone thru Carburetor" Did you check the Needle valve Seat? The ethanol gas ruins the seat if they are made of rubber and the needle valve is all metal.
Does the Float actually move up and down as it's supposed to? sometimes the ethanol gas absorbs too much moisture and the needle valve or pivot point of the float rusts.
Mar 01, 2015 | Toro Power Clear 418 ZR - Single Stage...
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Recoil starter
Go to you tube On the line repair recoil core
Feb 14, 2014 | Toro Power Clear 418 ZR - Single Stage...
Toro power clear will not stay running brand new
is the choke closed when you start this thing make sure you close the choke to start then shut it off , the plug gets fouled if you do not do it this way make shore you have the right gas mix in it , takes 50 to 1 I believe 2+2
Feb 08, 2014 | Toro Snow Blowers. Power Clear 621 QZR 21...
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
Toro Power Clear 418 ZR - Single Stage Snow Blower - Recoil Logo
370 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
