Question about Yamaha RX-V361 Home Theater Receiver
Our Yamaha Receiver RX v 361 Receiver can be used to conduct sound for CD's and DVD's as well as Radio/Stereo sound. It is used primarily as the sound system for our T.V. the setting is Multi Ch 5 when the T.V. is on however I changed the system to play a CD and now when I change it back the read out states Input Multi however no sound sometimes the word Muted flashes. I tried the Mute button for the Yamaha and the Cable Control however still no sound. How to I return to hearing the sound on the T.V. I have a picture.
    Genius:
  • Yamaha Master
  • 1,054 Answers
There should be a button on the front that says omething like multi-channel in. Press this to turn off the multi channel function.
Posted on Nov 22, 2013
4 Suggested Answers
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
easyq
  • 144 Answers
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Posted on Apr 17, 2009
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
I want to set the receiver to surround sound. The indicator only shows two speakers I want it to show five
What is the source of your sound? By default, receiver will use only those channels that are used in the input signal - if you play CD in stereto, it will use only 2 front speakers. If you play DVD with 5.1 audio, it will use all 5 speakers (+ subwoofer if you have one).
However you can use one of the bulitin "sound field program" modes to mix the 2 channel stereo music to all speakers. On front panel, press "PROGRAM < >" buttons to select the one you like. Or on remote control, repeately press MOVIE, MUSIC or STEREO buttons. You can check your manual for description of each sound field program.
Oct 11, 2014 | Yamaha RX-V661 Receiver
I have a yamaha rx-v463 and a yds-11 iPod dock that I can't get to work. My iPod comes on but I can't get any sound out of the speakers. Haven't used the iPod in a long time and I feel that I don't have...
First check the yam does play other sources of sound, e.g. radio or CD. Then try your ipod in another dock to check the Ipod is working.
Then check the manual for the Yam to be sure that you have set it to a mode where it will take in the signal from the IPod. Did you switch it away from IPod source to play a DVD or a CD or the radio?
Dec 19, 2013 | Yamaha RX-V463 Receiver
I just purchased a Yamaha RX-V465 AV Receiver, and I cannot get any sound out of it except for when I have Tuner selected. I have my OPPO CD/DVD player hooked up via HDMI and via the stereo analog audio...
Also the test tone is working OK (Setup / Speaker Setup / Test Tone)? Have you used automatic speaker setup with the supplied YPAO microphone?
For HDMI, you need to configure the receiver to "take" out the audio from HDMI. Go to Setup / Function Setup / HDMI / Audio and select "Amp" to route the audio to receiver, or "Amp+TV" for audio to go both to receiver and to TV. You can also check in Options Menu / Signal Info that receiver has recongnized the sound and what format it thinks it is in.
Jan 09, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
I have an RX-V663 audio sounds flat
Let's deal with the turntable sound first - unless it's a self-preamplified model you would have to get an external phono-specific preamp to use with this receiver. Without one you'll get microscopically weak, tinny sound from the turntable. Google "RIAA curve" to see why.
As far as the CD sound through the Blu Ray player... for one thing it is flat, as in two-dimensional stereo. Compared to genuine surround from a movie it would be a letdown.
Can you better define 'flat'?
Feb 04, 2010 | Yamaha RX-V663 Receiver
How do we listen to aCD in 5 channel suround sound without having the TV on we can only get straight sound. We have a Yamaha RX-V365 av receiver.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
Oct 27, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Conecting my EQ to my Yamaha reciever
your media out(dvd-cd-dat-deck player)-to equalizer in-and equalizer out to aux or cd in receiver.
Jul 17, 2008 | Yamaha EQ-70 Home Equalizer
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
Yamaha RX-V361 Home Theater Receiver Logo
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
