Question about Amana Washing Machines
Amana washing machine will not spin keeps shuting off
Broke the belt replaced the belt now when its time to spin it starts to spin and shuts off
    Genius:
  • 1,198 Answers
If it's a front loader, check the bearing, they wear out.
Posted on Nov 22, 2013
yalmer
  • 549 Answers
SOURCE: Washing Machine Belt Replacement
Here is the web link to a drawing wwhich I hope will help.
http://www.us1internet.com/AW300KW2_147217.htm
It is not the best drawoing but I hope it helps.
The tension wheel rides on the outside of the belt.
Posted on Feb 04, 2008
SOURCE: washing machine belt replacement
The repair sounds worse than it is.
2 hose clamps
4 big bolts
3 torx screws
a little wiggling and viola!
hints: take a good look (or digital pix) of the belt before you remove the pump, keep a few large towels around to handle the water in the hoses and to cover the front edge of the machaine to make it more comfortable when you're removing and installing the motor, the connector has a latch you have to press while removing the cable, the mounts for the motor frame/pump assy. need to be sprung out a bit when reinstalling.
Comment: the shaft from the motor is "double-D" shaped and slips into a plastic fitting in the middle of the pump. I don't see how you can break the pump unless you drop the motor assy on it...
Kudos to "sir fixalot" for giving me the courage to rip in to it...
Posted on Mar 05, 2008
SOURCE: washing machine agitates, but does not spin
my amana washing machine does not agitate, but it does spin
Posted on May 17, 2008
  • 71 Answers
SOURCE: My Amana washing machine stopped spinning.
moz-screenshot.pngac4805b.gifhere is the image on how to change the belt......it's pretty easy to do as you can see by the diagram.PS2027742 is the part number on the belt.
Posted on Oct 03, 2009
  • 901 Answers
SOURCE: install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Posted on Apr 06, 2010
Amana washer doesn't spin consistently.I have replaced belt and timer. Starts spin cycle and runs for about 6 to 10 seconds and shuts off.
Could be that the pump is binding which will eat belts up pretty quick, feel the belt and make sure it is not slipping and that it isn't all greasy and grimmy
Oct 09, 2016 | Amana Washing Machines
Amana washing machine dosent spin
Maybe door switch? Hear any humming? Belt might be broke.
Service Manual
Aug 04, 2012 | Amana NAV5800AW Top Load Washer
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Amana dlw330 washer belt burned & broke again after I replaced it
well if hte washer belt is "burning off"" that tells me the motor is trying to spin at full speed buthte transmision pulley is holding it back, can be a few issues, either the brake is notreleasing correctly or, the transmission is locking up .
Feb 26, 2009 | Amana 3.2 cu. ft. Top-Load Washer
ALW480DAW Washer Doesn't spin
had same problem grab agitator and rotate it clock wise and you should hear a clinging noise and try again to wash, it should be fine
cost free for now
Jan 20, 2008 | Amana ALW480DA Top Load Washer
Does not spin out all the water
Sorry RickAZ, I have just joined the fixya family. I'm trying to get old unsolved problems off the list, so I'm just posting a fix. Congratulations on your replacement washer.
Jan 03, 2008 | Amana ALW480DA Top Load Washer
Kicks out?
the smaller belt is causing the tub to spin too quickly. the shorter belt is causing the motor to overheat and causing the thermal overload protector to shut dowqn the motor. when the motor cools it starts up again. replace the belt with te correct size and that will solve your problems
Oct 11, 2007 | Amana NAV2335A Top Load Washer
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
