Question about Proform 585 CS Treadmill
We set up the treadmill in our kitchen, then discovered it didn't fit through the basement door. want to take apart and reassemble in basement. husband worries about braking it.
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video attached. God bless you
Posted on Nov 22, 2013
My sole f63 wont fit through the door, how can i take it apart?
see the video attached and proceed according. God bless you
Other alternative is your read the instr. manual and follow the section how to assembly or disassembly your treadmills.
Dec 06, 2012 | Sole Fitness F63 Treadmill
Cant fit it through the door to move to another room.
Only 3 choices:
1 - leave it in place
2 - Take it partially apart so it will fit through the door
3 - Widen the door frame.
Since the treadmill got into the room, it should be able to get out. Most likely #2 is the option for you.
Dec 07, 2010 | Nordic Track NordicTrack A2550 PRO...
I'm trying to put the oven door back together and it won't fit properly. any ideas? This is a whirlpool electric range mod# RF364PXPQ.
I had mine apart to clean and could not figure out how it went back together. The side strips I thought helped hold the glass in but they dont. I then discovered the side plastic strips go back in on the flip side-inner oven side. Grrrrrrrrr...wasted half a day trying to figure this out.
Nov 20, 2010 | Whirlpool RF364 Electric Kitchen Range
I need to move the treadmill and can't find the manual to find out how to break it down - won't get through the door! What is the easiest way to take it apart?
You will need to take out the screws on each side that holds the console to the uprights. When you lift up the right side of the console be carefull as you will need to disconnect the upright cable from the console cable. There is a clip to press as you pull the cable connectors apart. Tie a string around the cable connector that is in the upright cable that runs thru the upright as you will have to pull it out when reassembling. You can now lift the console off. You may be able to turn it on its side and fold the uprights down to carry it through the dorway. If it still won't fit, remove the struts too.
Oct 01, 2010 | Proform 380 CS Treadmill !
Life Fitness T3 treadmill won't turn on. Power from outlet is fine. 4 red lights are on by motor under front floor panel. Tried resetting, per owner's manual (pressing Stop and Down Speed), but nothing...
Could be. If you had to take it apart, I would definately check the wire harness connection. Also if there are bolts that were removed, check to make sure none of those pinched the harness when reassembling.
Nov 17, 2009 | New Balance 1400 Treadmill
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
Won't fit through door - taking it apart
remove the 3 screws in the arm trim cover and the harness unplugs there and the other wires are screwed to the frame right there. Philips head screws.
Mar 20, 2009 | Bowflex Treadmill Series 7
How to reassemble the oven door
shock981, did you ever figure it out? I'm having the same problem.
Apr 27, 2008 | Whirlpool RF378 Electric Kitchen Range
Proform 585 CS Treadmill Logo
122 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
