Question about ASUSTeK Computer Inc. SoundMAX Integrated Digital HD Audio
Asus w5g00ae laptop battery won't charge - ASUSTeK Computer Inc. SoundMAX Integrated Digital HD Audio
2 Suggested Answers
SOURCE: ASUS W5G00AE
sir plese explain your problem clearly.
Posted on Dec 17, 2010
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Despite of new battery my Asus PRO50 won't charge a 100%
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Dec 13, 2012 | ASUS Computers & Internet
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
Asus short battery life
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Feb 21, 2012 | ASUS Computers & Internet
Battery not fully charging
Aug 04, 2011 | ASUS Computers & Internet
My battery on my ASUS Eee PC 1005HAB died. Also, the Battery Charge Indicator stop working, I since replaced the battery with An ASUS 7200mAH battery. I ran it down till it was drained and tried to...
Check the voltage at the pins of the adapter. If present accordingg to the specifications then connect to the laptop and remove the battery from behind. Now check the voltage at the battery terminal of the laptop. if there is low or no voltage to the desired level then there are problems within the main board as this insufficient voltage will not charge the battery makeing it go down below level.
Jul 09, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My asus notebook won't charge i just bought last five days ago, and now it won't charge.. i tried to remove the battery and attach the adapter, but it still doesn't open..
if it wont charge it most likely has a bad battery...if you just bought it, I would suggest returning it for a replacement. Make the vendor or manufacturer make good on their product.
May 12, 2011 | ASUS Eee 4G Notebook
Computers & Internet Logo
26 people viewed this question
Top ASUSTeK Computer Inc. Computers & Internet Experts
Kolbrun...
Sandeep Kumar
Are you an ASUSTeK Computer Inc. Computer and Internet Expert? Answer questions, earn points and help others
