Question about Kenmore 27 in. Electric Single Wall Oven
Kenmore wall oven won't unlock after self cleaning
Tried cann I open it manually? still will not open.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Try disconnecting the power supply for about 10mins
Posted on Nov 22, 2013
4 Suggested Answers
SOURCE: Kenmore oven locked after celf cleaning
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
Posted on Aug 31, 2008
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
Kenmore oven won't unlock self cleaning
This often happens if the cleaning option was used, what happens is that the Thermistor burns out, this will have to be replaced, this is best done by a professional. If you want to try to DIY, then first you must obtain a service manual, and use the troubleshooting and disassembly instructions within. The best way is to call in a professional and simply ask for a "Quote" as to prospective costings and take it from there?
Oct 13, 2011 | Kenmore 33169 Gas Single Oven
I have a Kenmore oven model # 665.95024100 and used the logi-clean cycle and now the door will not open. This happened before when I used it and I called the repair service to fix it but I cannot remember...
Articles on the internet suggest not using the self cleaning feature of modern ovens, becuase fuses and other parts may easily burn out due to the high temperature.
Suggested methods to open a locked Kenmore oven at the artlcle at the link below:
http://homeguides.sfgate.com/clear-oven-lock-mechanism-kenmore-stove-71754.html
How to Clear the Oven Lock Mechanism on Kenmore Stove
Feb 26, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Oven door won't open after self cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 13, 2011 | Viking 27" Professional Select Built-in...
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
Kenmore wall oven door will not unlock after cleaning cycle.
heatman101
Nov 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I was doing a self-cleaning of my Kenmore oven. I tried to open the oven by moving the lever to the left, and it would not budge. Then I started getting a warning beeping and an F2 message. How can I get...
heatman101
Nov 06, 2010 | Kenmore Ovens
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 27 in. Electric Single Wall Oven Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
