Question about Casio PCR-272 Black Cabinet Design Cash Register
Printer ribbon is stuck
My printer ribbon is stuck printing over one column
  • 46 Answers
Printing mechanism broke; repair shop or replace. Many of these units use a little grooved shaft that shuttles the carriage holding printhead back and forth. If the carriage breaks (it's only a tiny tiny piece of plastic) or the shaft jams up (it's gear driven) or the miniature plastic gears lose a tooth or two or 20, it all stops. The printhead, not knowing anything is wrong of course, merrily prints everything right where it is: whatever column it got stuck in.
Posted on Mar 28, 2014
Hi my thermal ink ribbon is stuck to the unfinished photo and has stopped working the on button has gone red
Posted on Jan 18, 2014
I have a P5215 Printronix printer and it is not printing some of the columns. The tech cleans it however, after a while, it happens again. He says we need to use printronix ribbons. Is that true?
Yes the aftermarket ribbons are re-inked ribbons and are bad for the frets. If your tech cleaned the frets with an abrasive tool or chemical other than alcohol then he removed the protective film and the frets are bad.
Aug 29, 2014 | Printronix Line Matrix P5210 Printer
Printer is stuck
Go to Casio Support Webpage and download the Owners Manual.
Here: http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
Nov 22, 2013 | Casio PCR-272 Black Cabinet Design Cash...
THE TIME IS NOT PRINTING RIGHT ON THE CARD. THERE IS A LINE MISSING
A line is through the print because a needle within the dot-matrix printer is broken or stuck within the printer. This will eventually get stuck on the ribbon and tear a hole in the ribbon...and eventually led to complete printer failure. This can be caused by the running a staple or paper clip through the printer, yanking the card out of the clock while it is still printing or after years of lint build up (they are suppose to be maintained at least once a year). Try www.gatewaytime.com for an afforable replacemnt Gateway Time Systems Time Clock Sales and Service Pittsburgh
Sep 26, 2013 | Amano Pix-55 Time Clock
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
Its not printing
Make sure that you have a good ribbon installed and that the ribbon is advancing as the carriage moves. If the ribbon is not advancing it will only print until the ink has been used up on the section of ribbon stuck in front of the print head. It will also need a new carriage if the ribbon is not advancing.
Dec 21, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I have an Epson LX-300 dot matrix. The problem is the print is smudged/with black lines patches along the printed matter. The ribbon mask is lost. I'm curious to know the purpose of this ribbon mask. Does...
The mask stops this sort of problem and the print head could do with cleaning so that the pins don’t get stuck. The ink coagulates over the years and causes the pins to jam and eventually tear up ribbons of just burn up the driver coils in the head assembly. The head face needs cleaning with a cotton bud or two or three with isopropyl alcohol to remove all the ink residue from the pins and shafts. If you can remove the head assembly this is much easier to do.
Oct 30, 2009 | Epson LX-300 Matrix Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
Data card sp35 plus ribbon break
There could be either of the following issues:
1. Check the print head temperature to make sure that it is hot enough to transfer the ribbon to the card.
2. The surface of the PVC card may not be image compatible. Try another brand of card or opt to 60/40 composite cards for testing.
For technical assistance by blog for id card printers, see our blog at www.safecardid.com/blog/
Jun 20, 2008 | Datacard SP35 Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Casio PCR-272 Black Cabinet Design Cash Register Logo
101 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
