Question about RCA TruFlat 27F520T 27" TV
How to adjust the image on the Purflat RCA 27" TV
Part of the images are hidden on the right or left side of the screen
5 Suggested Answers
  • 11 Answers
SOURCE: RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Posted on Jan 08, 2008
bhur
  • 85 Answers
SOURCE: RCA tv.speakers internal
buy another speaker of your tv for replacement
Posted on Jun 03, 2008
  • 30 Answers
SOURCE: tv rainbow in screen
take it to a TV shop that have a special Degausser coil and they can professionaly remove the spots. Also has the sete been dropped? If so the tube could be damaged
Posted on Jul 27, 2008
pilot210
  • 39 Answers
SOURCE: multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
Posted on May 18, 2009
Picture is cutting off parts of images
Very few adjustments except in tech menu which I cannot tell you how to access--danger of killing set if wrong button pushed.
If picture just expanded top/bottom or left/right you may have a circuit problem
Mar 17, 2012 | RCA TruFlat 27F520T 27" TV
Hi, Expert: I have a 52" Sony LCD TV (
Hello
If I send you its schematic diagram and give you instructions, can you follow me?
Oct 18, 2011 | Televison & Video
In the game hidden secrets their is a segment on matchsticks puzzle you have to move 3 matches and make 4 squares you cannot go to the side or down but can go up.the puzzle looks like a grid of 9 squares...
Matchstick puzzle, 4 squares moving 3 sticks. Move the left side matchstick from the top square that is on the left side of your screen. Place it on top of the square you just took it from. Move top and side stick on the square that is on the right top of your screen. Place them on top of the top square that is on the left side of your screen. You should see 4 squares
May 05, 2011 | Computers & Internet
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
When I try to turn my RCA PURFlat 27" TV on, either with the remote or main button a blue line shows up in the screen and like within 2 seconds it goes off. What's the solution for this problem)?
My rca purflat doesn't turn on with the remote, batteries are good, it however turns on when I press the power button and then the channel button.
Sep 16, 2010 | RCA TruFlat 27F520T 27" TV
Smartimage problem on screen
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Apr 14, 2010 | Philips 220CW8FB 22" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
RCA TruFlat  27F520T 27" TV Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
