Question about Panasonic WORKiO DP-C262 Printer
The lcd display an error code ....E04-01...and i need to get into service mode to clear the message..thanks help please
I have try, different code and it dide'nt work
  • 794 Answers
Did you make a repair or replace the fuser and need to reset the code?; Because if you didn't fix the problem, you'll still get the same low fuser temperature error code.
Press <function>, <original size (ledger)>, <3>
to enter service mode, go to F9-05-04 (RAM Initialize, fuser reset, power off/on)
If the E4-01 error code returns you have a defective thermistor/thermostat.
Posted on Nov 22, 2013
  • Martin Ramdat
    Martin Ramdat Nov 24, 2013
    Thanks john for the solution ...but i make a mistake its not a DP-C262 IT IS A DP-C264 colour copier ...would nbe great if u could help me with this
  •  John
    John Nov 25, 2013
    Martin, I do believe that the error code you are getting is a generic code used by panasonic on many of their laser printers; so the error code still relates to a low fuser temperature problem. Since I don't have the repair manual specific to your printer model, try the original solution I posted earlier. Absence the repair manual, I would have to steer you to Panasonic's tech department. There would be no greater joy for me than to have a solution for you
Canon ir 3245 error e001
Contact the manufacturer or check manual that came with unit.
May 24, 2016 | Canon Office Equipment & Supplies
Key board not working COPIER>FUNCTION>CLEAR>ERR.
Do you mean the LCD display is not responding , or that the number keys do not work, or both? I suspect that the keypad and display do work but your real issue is that you cannot enter service mode to reset an error code. Entering service mode can be a little tricky on that model. Hit *(Add. Functions, not the * on the keypad). So , to review, * then the 2 and 8 key simultaneously, then * again will get you into service mode. A screen will pop up that says Copier and other stuff. Select Copier. Then hit function tab at top of display. Then Select Clear (CLR) Then Error(ERR) then hit ok at the bottom of display. Then cycle power, if the error resets, you are done. If the error comes back, you need a part. Important----do not randomly clear any other items in service mode. You can cause a lot of problems if you do. Only clear that error code. Hope that helped. If not, you need to call a technician.
Sep 03, 2014 | Canon Ir 3300 Black & White Copier
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.
3.Press the "SIGNAL"button.
4.Press the "DELAY START"button.
5.Press the "SIGNAL"button.
6.Press the "DELAY START"button.
Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
I have a canon 4080i error code e000004-0401 comes up and have to shut down when retart get the same message.
you have a fuser related error code, either thermisters or thermo fuse.
to reset error code you need to go in to a service mode and reset it.try this hit the additional fuction button then hit 2 and 8 keys together and additional function button again that will put you into service mode BE very careful in there though.
under function/clear/err code highlight err code then ok reset machine see what happens if error code comes back then you need to get a tech to have a look at ya fuser
Canon Tech
Apr 09, 2009 | Canon Office Equipment & Supplies
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Cant get rid of blinking error message, nothing works
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
Panasonic WORKiO DP-C262 Printer Logo
238 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
