Question about Health & Beauty
We have a Revo Scooter model S6824907026C30 the control switches will not work. Any suggestions or does anybody have a manual?
Replace Revo scooter power switch?
Have to remove the tiller cover to get at it.
Sep 12, 2015 | Blue Revo 3 Wheel Electric Scooter
Where is the controller on the revo 3 wheel scooter? Fault ( 9 )
hi , that 's is a internal fault, most likely a bad connection to the controller, at worse it 's a fault with the controller.
Regards
Rob
www.gewizrepairs.co.uk
Jun 25, 2014 | Pride Value Line Revo Scooter 3 Wheel
How do I start my revo scooter without a key
You don't. The key applies power to the controller. Without it there is no operation.
Oct 12, 2013 | Pride Value Line Revo Scooter 3 Wheel
NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Jun 11, 2012 | Pride Revo 4 Wheel Scooter
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
When moving foreward or in reverse after letting off of control scooter keeps moving about 1 foot. I have run into doors and other objects.
You don't mention what sort of scooter you have, but 90% of them have the same types of controllers made by two different companies; PG Drives technology and Dynamic Controls.
These, as well as most of the others, are programmable to adjust acceleration, maximum speed, and braking. You have to have a programmer in order to adjust these factors, which means you need to either buy one that works on your model controller, or find a service tech that has the programmer. Call the manufacturer of your scooter with the make and model number handy, as well as the serial number, if you can locate it on the scooter, and ask to speak with a technical rep. He'll point you in the right direction.
Jul 09, 2009 | Pride Value Line Revo Scooter 3 Wheel
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
