Question about Craftsman 25cc Gas Line Trimmer
Setting the rpm
Setting the operating rpm
    Top Expert:
  • Craftsman Master
  • 12,540 Answers
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Posted on Nov 24, 2013
I set my trucks RPM on a low setting, from inside, no engine tampering. Now it is warmer. My truck is still running at a low RPM, seems too low for current temperature. How can I adjust my RPM?
how did you adjust a pre-programmed ECU idle settings ??? please be more specific
the vehicle's ECU is pre-programmed to run higher than 1000 rpms while in "open loop mode" then idle back down to ~750 rpms once the engine reaches operating temperature "closed loop mode"
did you tap into the OBD 2 port and used a laptop to change the settings?
Mar 15, 2015 | 2000 Nissan Frontier
Center air vents
cant think why going at a higher rpm could change the vent setting but at a higher rpm the a/c will get to a lower temp so perhaps the vent setting knob is at fault and the vents are set to floor and not the panel. i'd investigate the vent knob operation as a first step let me know how it goes
Apr 22, 2014 | 2005 Dodge Dakota
I was accelerating away from traffic lights,i was waiting for it to go into top gearand the stop light came on, i lost power steering and engine cut out. i turned everything and started it again with no...
Check what rpm's you had when the engine cut out as you probably exceeded max rpm's setting for safe engine / rear box operation as set by sensors in the ECM
Apr 19, 2014 | 2000 Renault 181
Rpm idle setting
my 98 chevy 1500 with 5.7 and 373 gears idles at 600 rpm, and at 55mph its running 1500 rpm on the dot
Mar 01, 2012 | 1999 Chevrolet Silverado 1500
Sony ps-lx250H turntable only spins at 45 RPM
It seems to me that the switch has broken and isn't moving to the 33 setting. You just need to find the switch. Without seeing it I can't say what type it is so I suggest looking for it under google image search. Try "micro switches" or "leaf switches". You can also look try Maplin, or the Curry's Partmaster website.
Nov 11, 2011 | Sony PS-LX250H Turntable
What is the high speed rpm setting for a intek 22hp vtwin?
Generally 3,600 rpm is the high speed setting for many of these type of engines.
Mar 03, 2011 | Briggs & Stratton Briggs Stratton Intek V...
How can i increase or decrease settings? rpm low when warming and running low during normal operations? checked timing it's a 0 tdc. increasing idle speed works with rpm setting and carb?
What is Make, Model ,Year, and Engine?
Does this have a distributor?
Many GM's run a few degrees advance of TDC (Top Dead Center) on ignition timing.
If it has a carburetor, be sure to unhook and plug the vacuum dashpot advance line .
It sounds to me me like you're experiencing a retarded timing condition, which, among other things could cause a slower than normal idle.
Jan 16, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I have a primary jet and secondary jet in the carburator of the 500 gl silverwing . and the jets I have is 75 and 125 which goes where . and what should be the setting on the air jet ?
The secondary main jet (125) goes into the jet needle holder in the center of the carb (needle). The primary main jet (75) is between the secondary main jet and the pilot screw (this one is slightly off center) . The start setting for your air screw should be 1 3/4 turns. Warm up your engine and drive for ten minutes. Adjust your idle speed to 1100 + or - 100 rpm. Now turn pilot screw in or out to get highest idle speed. Readjust idle to 1100 rpm. Now turn pilot screw in till idle speed drops 100 rpm. If pilot screw seats go to next step. Adjust the pilot screw out 1 full turn from 100 rpm drop point. Now reset Idle to 1100 rpm. That is how Honda says to set your air screw. Standard setting is probably sea level and going through the procedure will set you up for the altitude where you ride. Do the adjustment during good weather at the altitude you plan to do the most riding.
Aug 27, 2010 | Honda CX 500 B Motorcycles
My 99 suburban idles at 1000 rpm in park with a new TPS at operating temp. What is the factory idle setting? how do I adjust rpm?
There no adjustment for idle, control by computer, TPS reading should be .50 volt's, you could have a vacum leak, check vacum line and check for vacum leak at base of intake manifold.
Jan 21, 2010 | 1999 GMC Suburban
Chamberlain door will not close, despite down force set to max
Problem solved, sort of-
My unit has self diagnostic capabilities: next to the remote sync red button, is a yellow light the indicates diagnostic readings by blinking. In my case the light was flashing 5 times after the door failed to close. This meant RPM sensor failure. I rechecked the sensor and "flywheel" cap and found that it was not completely secured. With the "flywheel" in the proper position, providing readings for the RPM sensor, the door completely closed.
But my yellow diagnostic light is still flashing 5 times. My door is operating correctly, but the diagnostic feedback is still not completely happy with my RPM sensor. So I will keep and eye on it.
Oct 11, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman 25cc Gas Line Trimmer Logo
48 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
