Question about Polaroid TDA-03211C 32 in. LCD HDTV
Input locked Video works, but whichever one I select I get what looks like a screen saver (words are moving around the screen) that says "Input Locked". I bought it used and not working, replaced the caps, guessing it has parental controls or something turned on? I'm electronics competent if it requires me to do something on the board, just let me know what you think, thanks!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
I think its in store mode
Posted on Nov 22, 2013
  • 814 Answers
SOURCE: polaroid flm-373b
You may be having a problem with the parental control, This control has a video lock. You may need to unlock this to get the video working again. If you have your owners manual, you can find the instructions for unlocking the video on page 41 of the manual under parental settings. If not you can find a pdf copy of the manual on this link to Polaroids customer support website http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT123&folder_id=0 If this does not help you, the customer support telephone number for Polaroid is 1-866-289-5186. They should be able to tell you how to get the functions of your television working again. I hope this information helps you with your problem.
Posted on May 28, 2009
  • 883 Answers
SOURCE: VGA input
is your laptop capable of sending widescreen video to your TV or can it only send 4:3 video?
Posted on May 25, 2007
Benimur
  • 6966 Answers
SOURCE: Only see a blue screen ...
Hi, The bluescreen is an indicator of "lack or absence of a video signal". In TV mode this would only come on if your reception quality is so poor that the TV "thinks" there is more interference/noise than intelligent video signal nd therefore mutes the video. In all other modes, (S Video, A/V Video etc), again, this muting action will result in the bluescreen if the TV "thinks" it is not receiving any video input. To try and fix this would either be: 1. Check and verify that you have a video signal coming into the TV by trying your video source (DVD, cable box) into another TV unit; or 2. Check and verify that your connectors at the back of the TV and the source are properly connected and are snug/fitted properly. If both fails, it is possible that you have component failure inside the TV and that would require the services of a qualified TV professional. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 15, 2007
StevenPolloc
  • 28 Answers
SOURCE: FLM-323B HD blue screen, no signal.
for the remote change battery or get new remote, For the TV make sure that your cable is plugged in properly and not half out. or has it previously been wet. Reason because it sounds like your TV has had a static charge.
Posted on Jul 03, 2009
gripfitter
  • 557 Answers
SOURCE: cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Posted on Sep 21, 2009
Nothing on screen when DVD inputs are plugged into our Aquos.
Check that the input you are plugging the DVD into on the TV is actually selected as the TVs input. Try using a different input and also different input types/cables. Most DVD players will have HDMI and also either component or composite type outputs. Try the different cable type and make sure the TV is looking at the correct input. Do you have sound?
Feb 11, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My camera is hooked up to my tv as instructed but nothing happened. Is there a special channel that you put your tv on in order to get a view
Connect the yellow connector of the camera to the TV Video input 1 or 2
Using the remote select the right video input on your TV by pressing, Video or Source on the remote to select the video input 1 or 2 whichever, input you connected the camera to that input needs to be active using the remote or keypad on the side of your TV set.
AAA TV SERVICE
http://www.aaatvservice.com
Aug 20, 2011 | Lorex Corp SG6184S Weatherproof Mini Color...
Sanyo just says no signal Screen is blaack except for NO SIGNAL moving around all over the screen
This happens when there is no signal.
For instance, if you have the screen set for VGA input, and either the computer is off, not connected, or in screen saver mode.
Check to see what input is selected, and more importantly, if there is a signal at that input!
Feb 24, 2011 | Sanyo Televison & Video
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
The laptop blockes if i don't use it more then 10 minutes
Assuming that this is a Windows laptop, rigth-click anywhere on the desktop and follw te relevant section
XP or Vista: Select Properties then Screen Saver from the tabs at the top
Windows 7 : Select Personalize and Screensaver from the bottome right
There will be a box sumilar to this:
Either increase the time or untick the "On resume display logon screen" option
Nov 30, 2009 | Acer Aspire 5315 Notebook
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
Bose Remote Control RTC1T-27
I called Firedog and paid them $80 to come out and fix it.
Jan 04, 2009 | Bose Lifestyle 20 System
Sony trinitron xbr 32"
Did you correctly select the S-Video input on the TV via the remote? In other words, if the TV is not set to look at the S-Video input then nothing will happen. You have either an "input", "source" or tv/vcr button that will allow you to select what input the tv will look at for a signal. Make sure it's set to S-Video.
Nov 13, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
22 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
