Question about Tablets & eReaders
Asus transformer wont boot up
The tablet will come on enough to show the logo but nothing else. it worked fine the last time I used it. when I plugged it in to the computer it gave me a code 10
    New Friend:
Call asus
Posted on Nov 22, 2013
5 Suggested Answers
  • 65 Answers
SOURCE: I need a user manual for an Asus Transformer
The link for your transformer is here:
http://dlcdnet.asus.com/pub/ASUS/EeePAD/TF101/TF101_Full_0418d.pdf
Posted on Jun 19, 2011
  • 4961 Answers
SOURCE: Screen problem with Asus TF300 10" tablet
Did you put a new battery in it or did you buy it used? Because it doesn't like the battery.
Posted on Aug 19, 2012
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
jasonnashjlu
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Posted on Nov 09, 2013
I have an acer iconia 500 tablet, it worked fine last night ,but today it wont get past the acer logo on boot.tried to do a hard reset and push button reset no joy ,any advice would be welcomed
lol I know that feeling...you need to reinstall the bios...you can find them on a flash drive on ebay. Or go free and use a flash drive to get it free online...go to acer.com...Its a known problem by Acer :) update: My Acer 500 stopped working Friday, with the very same freeze at Acer startup screen detailed here. Reset button didn't work (there's a post here that said he pressed the vol/up button while pressing the Reset button-I've only been inserting the tip of a paper clip to press button, which is the correct way?
Did the hold power button while pressing vol/up then sliding lock button back and forth. "Erasing Cache" appeared, but screen goes back to Acer startup and nothing.
Found this thread from a poster at Androidtablets.net. Downloaded one of the zip files posted here. Went to copy to an SD card, Can the file be placed on a USB drive instead? While trying the power "Bootloader vo.03.12-ICS Fastboot USB Download
Aug 13, 2016 | Acer Tablets & eReaders
Nothing happens when I rub my mouse keyboard on my Asus Transformer T100. How do I get it to be visible
Ok I have been thinking about your problem. How long did you actually charge your Asus Transformer?
You might need to charge it about 8 hours minimum to get it to work efficiently. Try that and see what happens.
Jan 05, 2015 | ASUS Transformer Book T100
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
My ASUS Transformer will not power on
1. Make sure it is charged. If the battery is dead you may need to leave it plugged in for a few minutes before it will turn on.
2. Hold the power button down for at least 10 seconds. This may bring it back to life if it didn't shut down properly.
3. Make sure no other buttons are stuck down (volume up or down). If another button is stuck down the power button won't work.
Apr 16, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Dec 11, 2012 | ASUS Transformer Tf300t Tablet
My Asus Tablet will not turn on
With the tablet turned off, press and hold the volume + button...now press and hold the power button at the same time....you should see a list of options...use the volume + button to scroll options. select recovery mode then push the volume - button, try to "reboot system now", if that doesn't work, you may have to select "wipe data factory reset" but this will wipe all of your apps, and restore the tablet to out of the box condition.
Oct 20, 2012 | ASUS Tablets & eReaders
Broken charge port on asus transformer prime
take to your local repair shop it will cost £25 to repair
Mar 01, 2018 | ASUS transformer prime eee pad tf201-b1...
ASUS Tablet TF101 Wont Charge
batteries do not last forever get it replaced by a computer shop
Jan 05, 2018 | ASUS Eee Pad Transformer TF101A1 Tablet...
Tablets & eReaders Logo
66 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
