Question about YouTube Videos
Evan tube hd - YouTube Videos
2006 vw jetta wiper still not working after changing the wiper motor and wiper switch ? help
Did you check the fuse? Have power at the plug? could be a bad ground.
Dec 06, 2015 | Evan Cars & Trucks
Where does evan from evan tube hd live
he lives in Los Angeles, CA
Apr 26, 2014 | YouTube Videos
Amp hum
Could be a couple things. Check grounds. Make sure cables do not have broken conductors, Make sure all tubes are fully seated. look for broken wires on chassis, spray a little contact cleaner into the jacks and insert and pull out plug a few times to clean the interrupts. Check the tubes for heater to cathode shorts,
Check for florescent lighting and similar noise sources with an AM/MW transistor radio, and if nothing is found externally, then you need to look at the condition of the filter caps in the power supply. The filter caps "may" show signs of failure, such as bulging, or leaking a black ooze, but they can also fail with no outward evidence.
Dec 17, 2012 | Peavey Envoy 110 Transtube Guitar Combo...
This been happening since yesterday n it Still does not work I thought it was due to being to hott n I tried it today when I woke up same results
The power supply has went on it, It is not cheap to have it (Repaired) Just go end get a different tv, It can cost $165 to over $200 to have it repaired, You can buy a old style tube tv for less then that, Some people evan give them a way (Free) They all want (Flat screen (TV,s) now a days ,If they can afford to get a (Brand) new tv. Where i live i have picked up the old style tube (TV,S) from beside a garbage bin that have worked. End give them to people that don,t have a (Tv) in the (Apartment) Where i live.
Oct 24, 2012 | Televison & Video
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
YouTube Videos Logo
64 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
