Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Verbatim 4gb Every time i plug in the verbatim, the only thing that comes up is the security part. I have windows xp. Will it work on my computer?
  • dlb4500 Nov 06, 2007
    I've got the same problem, but it is with the 2 gb.
  • tamjam30 Dec 29, 2007
    cannot get the manuel disk to work on my pc...without the manuel i cannot hook up my wireless mouse! It is a verbatim corp top wireless travel mouse.
  • 106 Answers
Please use the CD came with the drive and formate it full. Reconfigure everything so that it will show the patition that you want in the window. Do not worry 'bout the Data. you can recover all by using data recovery software available on the net. Try google serch.
Posted on Oct 13, 2007
SOURCE:
I have just bought a Verbatim 4GB PinStripe USB Drive. My Windows 7 computer at home will not recognise it, and nor will most computers at work (Windows xP Professional). The shop replaceed it, but the...
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
Aug 16, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Purchase 5 new verbatim 4gb when i plug it into pc the system found new hardware and installed . then it allow me to used two of the drive. when i plug it in the pc a msg appear, u need to format the disk...
You have to format the drives. If you put data on the drives using computer 'a' whos OS is MacOS and then you put the same Drive into computer 'b' which has windows, it may not recognise the file system/structure.
Nov 23, 2017 | Verbatim Store 'n' Go 4 GB USB 2.0 Flash...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Plz Help Me
I'm not an expert with PCs, but I have a windows 98 Operating system and have been able to use all sorts of flash drives. Everytime I buy a new one, I just plug it into the USB port and in a short time it recognizes NEW HARDWARE and loads the driver. I've used LEXAR 2GB,SANDISK 4GB, VERBATIM 2GB, and recently a ATIVA 4GB
Apr 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Verbatim 4gb flash drive settings causes error
Factory reset the unit. Hole on the back. Insert paper clip and hold for 10 seconds
Oct 02, 2017 | Verbatim CORPORATION 94933 USB 2.1GB...
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Verbatim 8GB Styore N Go USB HD
I feel like the device should show up in "My Computer" unless it is defective. However, there is some Vista Security Software and a downloadable pdf file on the Verbatim Website that describes driver issues with the Store and Go. See URL below
www. verbatim.com.au/products.cfm?productID=99507&cid=2
Normally, these things only need drivers for win98SE
May 24, 2008 | Verbatim Computers & Internet
Logging into my memory stick
If you are running windows vista, try right clicking on the locker -select properties-select compatibility tab- check mark the run in mode box and run the application in windows xp service pack 2 compatibility mode or another mode listed. If this doesn't work then your drive might have become corrupted, either from static electricity from being plugged/unplugged with your computer on, or coming too close to a magnet etc... Always back up your data. Good luck.
Mar 06, 2008 | Electronics - Others
Verbatim Store n' Go 1 GB
i have windows 98se operating system .i am not able to access this .pl sent free software downloads
Dec 19, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
137 people viewed this question
Top Verbatim Computers & Internet Experts
gggg
Don Hart
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
