Question about Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount
Craftsman 32" 10 hp
What is the proper operateing rpm.
    Sergeant:
  • Craftsman Expert
  • 417 Answers
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Posted on Nov 22, 2013
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor · Operation Manual.Craftsman Lawn Mower manuals - ‎Craftsman 247.370310 - ‎Craftsman 247.37030
Aug 02, 2015 | Craftsman Garden
Do you know the specs. on motor of craftsman 10"tablesaw model 315228410
Is there a nameplate on the old motor? If so, it should state the HP, speed and direction of the original motor. If not, a 1/2 HP to 1 HP 1750 RPM motor with the same size shaft that will turn the blade the same as the original should work fine. From the online manual, it appears to have an internal start switch, so the wiring should be standard.
Jun 22, 2014 | Craftsman 10" Table Saw
After about 15 minutes of operation my mower just cuts off as though it ran our of gas but has not. I have replaced the ignition coil, spark plug, air filter, fuel filter. I have a 17.5 hp Craftsman riding...
I have same problem only thing ive found is gas tank may not be venting properly. Fill tank about half full and leave cap off, if still stalls then probably engine problem
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp, Starter will engage, will not go past the compression stroke. Checked valve clearance, it is fine. Mechanic says it's probably not the starter. HELP?!
I'm not sure of the engine in your machine but i can tell you that all small gas engines have some sort of de-compressor,be it on the cam or a simple" bump" on the camshaft.It sounds like yours is not working.Some briggs engines need the valves adjusted until there is only 120lbs of compression during cranking to aid in starting,when it does start the compression will go back to normal as it comes off that "bump" with engine rpm.Check with your dealer for the proper adjustment of the de-compressor.
Mar 23, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1/2 craftsman garage door opener is not traveling more than 10 inches, it is not hitting the limit switches df
The final locking piece on the motor shaft (the one with 2 set screws) was not far enough onto the shaft. The plastic cap that works with the RPM sensor would not sit far enough on the shaft and was not being read by the sensor.
I held the motor shaft in place from the front and pressed the ring further onto the shaft; tightened the set screws and pressed the plastic cap back on the end of the shaft.
The RPM cap sat far enough into the sensor for the door mechanism to work properly.
Jan 27, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
My craftsman door opener went up half way and stopped. Light on u nit was not on and indicator light flashed 5 times, the repeats 5 flashes. billybob
The code for that light flashing 5 times is 'motor overheated or RPM sensor failure'. The RPM sensor is a small printed circuit board just in front of the motor. Release the door from the opener and operate by hand. It should raise easily and should stay put when it is about waist high.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens and then closes wright away
I figured out that when I replaced the gears, I damaged the RPM sensor. It was easy to swap out the old for the new and now it works fine.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount Logo
116 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
