Question about Roland Boss BR 900cd Digital Recorder BR 900
Enter button not working
I'm sending this again because the last time I had a typo in the subject line. I have been using this recorder for many months with good results. Last week I noticed that the I had to hit the enter button several times in order to get it to work. A few days later it was working fine again. Then it seemed that I had to wait longer than usual before recordings or edits were processed and I could proceed. Then the enter button just quit working. Everything else seems to work fine. I can record, play back, change virtual tracks and go through all the menu options until I have to hit the enter button and then I can't go any further. I would really appreciate some help, because I use this machine a lot.
If this is a traditional keyboard (not laptop) or extremely fancy keyboard.
Try unplugging the keyboard. Then.
  1. Take a butter knife and slide it into the crevice next to the "enter key".
  2. Apply a small amount of pressure to pry the key upward.
  3. With little effort the key should pop off or slide off.
  4. Check the spot the key was for dirt, dust, food, etc. Clean it if you must. Make sure the actual key does not have anything stuck to the bottom of it.
  5. Push the key back onto it's place on the keyboard.
  6. Plug back in and see if that worked.
If this did not work, you may need to replace the keyboard OR you may want to make sure no viruses are playing an aweful trick on you.
Posted on Nov 22, 2013
  • Nathanael Edwards
    Nathanael Edwards Nov 22, 2013
    Accidental post. I assumed that I was still in the computer category.
4 Suggested Answers
  • 5603 Answers
SOURCE: I bought mv 8800. I
This is NOT likely to be a problem with the power source at all but more likely with some setup parameter. Search your manual for subjects like "quantize" and also sampling rates.
Posted on Dec 02, 2010
  • 5603 Answers
SOURCE: Hello, My Boss CS-3 Compression Sustainer
Make sure you use Alkaline battery and NOT rechargeable type... the rechargeable battery will NOT work in the pedals (their voltage is lower even though they are labeled as 9 volt replacement).
Other internal problems can be due to cracked circuit board or broken solder joints. These are very common as people step on the cables when plugged in. This breaks the connection inside. A fuzzy sound often occurs when one of the contacts is marginal due to bad solder at the jack terminals.
Posted on Mar 22, 2011
Testimonial: "Thanks"
  • 5603 Answers
SOURCE: Hi There. I am having
I assume you have tried formatting the card in the BR900... sometimes formatting in the PC's doesn't work. read at this web page:
http://launch.groups.yahoo.com/group/BossBr/message/1905
Posted on Jul 07, 2011
What is the correct procedure for resetting Yamaha P 85 Digital Pian?
Resetting Instructions:
1) Try a partial reset by holding down the last white key while turning the unit ON.
2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
Jan 03, 2014 | Yamaha P85 88Key Portable Digital Piano
What is the correct reset for Yamaha P 85 Digital Piano?
Reset Instructions:
Enter buttion not working
Hello, that seems to be a bad contact on the enter button, the solution is to take a part the key and clean it, otherwise you need to replace the under key switch.
Thanks
Nov 22, 2013 | Roland Boss BR 900cd Digital Recorder BR...
The audio kept cutting in and out while using the Samson Stage 5T 3-in-1 Headset Wireless. It lost audio for about 30 seconds at a time. At the time, it was connected to a Samson MR 1064 Mixer that was...
The unit is SUBJECT to radio interference from other systems in the area such as high power taxicab radios for example and other services. 30 seconds might be about the time for a radio transmission. The system, while being interfered with, likely will NOT generate audible sounds and due to the squelch algorithm may MUTE the system.
Sorry, but you are a SECONDARY user per FCC definition and they are licensed and you are sharing bandwidth. You cannot interfere with them, but they can interfere with you. You should probablly get a UHF system that has less chance of interference. While recording, frankly I would be wired, not wireless. I am both an electrical engineer nd a HAM so I am aware of these problems.
Mar 28, 2011 | Samson Stage 5T 3in1 Guitar Lavalier and...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
1) how to make my amp record....because its not working when i try... 2) do i have to a cord in line 1 and 2??? 3) do i have to plug in the cord in :.....line in or line out??????
You will use microphone with balanced XLR connector into the XLR mic input. Note, the ALpha does NOT have phantom power so you cannot use condenser mics.
A guitar can be plugged into the hi-z instrument 1/4 inch jack on the left front of the unit.
To use the line 1/4 inch inputs you will use BALANCED TRS 1/4 inch cables from your source.for these channels. The level on these needs to be line level.
The line outs are for sending audio out to an amp. There appears to be RCA outputs you can use as well.
I am not sure what you mean by making your "amp record"... An amp PLAYS the audio, usually into a speaker.
If you are trying to play a guitar through your amp AND record, then you will connect your guitar to the Alpha, the amp input will have a cable from say Line 1 OUTPUT and when recording wou will have the echo feature on so your guitar is passed through to the amp.
Jan 09, 2011 | Lexicon Alpha Personal Recording Studio
I bought mv 8800. I bought converter which converts from 250V-50Hz to 110v 50w So I get into my mv, with vga mode, and i see software with lags, not freezing but for example i play beat, it records not...
Dec 01, 2010 | Roland Mv8800 Production Studio
Br8...the enter button has become harder and harder to make activate...now nothing. Everything in the unit works fine...except the enter button...which means that I cant record anything at all.
The button is obviously bad... The next thing is to determine what type button is used, It may be a small module or it may be a conductive rubber one. The latter, you take apart and clean with 99% isoprophyl alcohol and QTips. The module type you unsolder and replace the little module.
May 28, 2010 | Boss Micro BR Digital Recorder
How to use an external effects processor on the tascam neo
Manual here:http://www.fullcompass.com/common/files/10255-Tascam%202488-neo%20manual.pdf If you look at the back you will see two effects sends. Apparently from the manual you can use the line inputs for returns. This is where it might become confusing. Each line in is also a TRS jack. That means that using a common guitar or unbalanced cable will make the jack act as an input. If you use a shielded !/4" stereo cable( stereo jacks on each end) then the jacks can send a signal and receive a signal. If your effects unit has one of these jacks also you just need the proper cable. If not you use a cable with ends that match your unit and the Tascam. There are several combinations of effects assignment available and you should consult the manual carefully. I would recommend joining a support or users forum for this unit. Try this one:http://www.sweetwater.com/forums/showthread.php?t=25978 or this one:http://homerecording.com/bbs/showthread.php?t=276889 The last one is a site worth joining and I highly recommend it.
Feb 04, 2010 | Tascam 2488mkii 24 Track Recording...
I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Nov 16, 2009 | Boss Micro BR Digital Recorder
Roland Boss BR 900cd Digital Recorder BR 900 Logo
130 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
