Question about Exhaust for Mazda Tribute
Manifold gasket can u change the rear exhaust man gasket on 03 trib from the bottom.looks like a roid cuz ya cant even see the blts?
Yes but you have to drop the exhaust
Posted on Nov 22, 2013
Removing exhaust manifold on a 2009 LR2 Land Rover
4 bolts top, 4 bolts bottom, 3 nuts connecting down pipe. 1 exhaust manifold gasket. Spray with PB, soak, remove drop in new exhaust manifold and gasket
Sep 29, 2016 | 2009 Land Rover LR2
How do I remove the water outlet on a 2000 Oldsmobile intrigue GX 3.5 L V6?
OH man, thats a fun one!
You will need to remove the exhaust pipe from the rear manifold, remove the rear exhaust manifold to head bolts/nuts, remove the crossover pipe (which I believe is part of the rear manifold) to front manifold bolts. You will then be able to move the rear manifold enough to get at all the bolts for the water outlet and replace the four gaskets.
These are a real pain in the asphalt!
Jan 25, 2016 | Oldsmobile Cars & Trucks
How do i change the manifold gasket on 1995 camaro
Intake or exhaust manifold? Intake manifold is gasket is a pretty big job that gets complicated even further with tight working quarters under the hood of a camaro. You have to remove the fuel injection system to access the intake. you may also have to remove some of the drive accessories, e.g, AC, alternator, etc. GM was using a two piece intake for a while. not sure if your car has one or not. you will need to get gaskets for the upper and lower intake. you will need a large assorment of tools and several hours to perform the task. Get a repair manual and look over the procedure before starting. Locate all the components the procedure mentions. Follw the instructions and take your time. Lay everything out in an organized manner as you pull it off your car. Keep everything clean and be careful not to drop anything down the intake ports...Reassembly is just the opposite, keeping things organized will save you time going back together. good luck. exhaust manifold will be a major pain in the backside. pay somebody if its the exhaust
Dec 27, 2014 | 1995 Chevrolet Camaro
My 2003 crown vic is making a loud noise from the top of the motor towards the back drivers side i have already changed the exhaust manifold gasket on that side
You changed the exhaust manifold gasket. Did you take a look at the exhaust pipe, the end connections into the exhaust manifold, and the connections into the catalytic converter? There could be a small hole that that is large enough for the sound to be heard. If you don't know what to look for, have a mechanic look over the entire exhaust system for you. You may be surprised at what they may find.
Dec 12, 2014 | 2003 Ford Crown Victoria
Exhaust manifold leak
Hi Kevin,should of bought a 85 nissan 720 4x4,lol,here's a link to replacing your gasket,join the site,it's free then you can use their repair guides.Check my video out.
Nov 22, 2013 | 2003 Mazda Tribute
03 Monte Carlo no power
You have a vacum leak. It is going to be ya intake manifold. Best way to check it is to use some starting fluid and start the car and spray a very little around the intake. If the motors rpm goes up you know you have a bad intake gasket. If it doesnt then look for a vacum leak in the rear of your motor. There is about 4 vacum hoses there and one could be dryed out from the fire.
Nov 25, 2012 | Cars & Trucks
I have a 1994 Ford F150 extended cab 5.0 v8. I need to change the exaust manifold gaskets, how can I do this and what tools and what will I need to do?
Hi! Here are some guides on removing and replacing the exhaust gasket:
- You may need a 12mm and 14mm closed and opened wrench
- Make sure that the engine and exhaust is cooled down before performing the procedure to prevent injuries.
- The exhaust manifold may have a cover, please remove it using the wrench
- Once opened, remove the nuts of the exhaust manifold
- Support the exhaust before pulling it out for it may hit the ground
- Place the new exhaust gasket in place
- PUt the exhaust manifold and tighten the nuts evenly
Hope this helps and good luck!
Apr 07, 2010 | Ford F-150 Cars & Trucks
I cant locate the knock sensor on my 98 honda accord. ive looked all over the engine block and cant seem to find it.
Under hood, center, lower engine area, above exhaust pipe flange, mounted in exhaust manifold
Sep 03, 2009 | 1998 Honda Accord
Exhaust for Mazda Tribute Logo
46 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
JOHN LAPIER
Gary Nitowski
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
