Question about Panasonic KX-FPG376 Plain Paper Thermal transfer Fax
Volume control The speaker phone volume can't be adjusted. It is stuck on high. Pushing the - on the control button results in the LCD display changing (bars up and down) indicating a volume change, but the actual volume is still quite high.
    Genius:
  • 2,120 Answers
Is there a sliding switch on the handset or on the left side of the machine?
Posted on Nov 22, 2008
SOURCE:
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have an 17" (2 in1) n Tru Tech LCD TV (with built in DVD player) The volume can not be adjusted, whether I is the remote or volume control on the TV. It goes to#15 and stays at that volume. What Can I...
I assume "#15" is the displayed volume setting on the screen when you try to adjust the volume. Is this the maximum? If so, perhaps the front panel volume up button is stuck on (not the remote control; nothing else on it would work if that were the case).
Another likely cause is the TV's microcontroller chip or memory chip that goes with it has a fault in its volume control address location.
You can check for a stuck button by comparing its feel with the volume down button when you press it. If it is stuck, the difference in action will probably be noticeable. If you can't tell any difference, the set needs internal repair.
Oct 22, 2010 | Televison & Video
How to turn up speaker volume on my nokia n95 phone
On the right side of the device there are three silver buttons: volume control, camera button and a button providing quick access to the Gallery.
When you are in speaker, adjust the volume using the volume control buttons by pushing up or down
Jan 03, 2010 | Cell Phones
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
They are makeing a constant sharp noise a loud high pitched hum if you will
Right-click on the speaker icon in the lower right of your screen and choose Open Volume Control and check all volume levels (make sure they are not set to high). If this doesnt work then when you right-click, choose Adjust Audio Properties and search around for volume controls (maybe try the Speaker Volume button).
Aug 04, 2009 | Audio Players & Recorders
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
GN 9120 beeps constantly
Are you using the GN1000 Handset Lifter? And if so, are you playing music/radio through the speaker of your telephone? If this is the case the Lifter will be picking up the sound of the music coming from the telephone and interpreting it as an incoming call, hence sending a signal to the earpiece in the form of beeps. Just stop the music coming from the telephone and the beeps should stop.
If you are not playing music through the telephone, you may need to turn down the sensitivity adjustment on the back of the Lifter. Just turn the knob anti-clockwise a little bit and see if that eliminates the beeping. If the sensitivity adjustment is too high it will pick up every little noise that goes on around your desk and interpet them as the phone ringing.
If you are not using the GN1000 Handset Lifter, then the beeping may be the result of a sticking/stuck volume button on the earpiece. If you adjust the volume on the GN9120 it gives a beep when you reach the maximum or minimum volume. If a button is stuck down it will result in a constant beeping. A stuck button is generally not a user servicable problem, however a little bit of tinkering with the button may get it unstuck.
Nov 19, 2008 | GN Netcom GN 9120 Professional Headset
Volume
hi pkeyes40, my phone is a differenet model number, but on my phone you raise the volume by hitting the hands free button, then press the delete button several times to adjust the volume ( 1-4), then press the hands free button to confirm. then hit delete to exit. hope it works the same for your phone. good luck. and if you would like me email you with the manual i have for my phone, an innovage lcd phone/caller id 1507102, it might give you some pointers. my email address is [email protected]
email me and i reply with the manual. hope i helped ya out. good luck.
tammy
Mar 27, 2008 | Innovage Touch-panel Phone 1502084
Panasonic KX-FPG376 Plain Paper Thermal transfer Fax Logo
145 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
