Question about Kenmore Elite HE4 Electric Dryer
I have a ge model# gtdx100emoww electric dryer that will only work if the start button is held in. Once released it stops.
Works fine on all settings with start button pushed in. Nothing works when released. Could this be start switch at the motor? And is it easy to change?
    Genius:
  • 1,198 Answers
Yep, it's the start/run switch at the motor, can get stuck with lint after a long time. It's actually not too difficult to change, make sure you note the location of every wire. Clean everything real good with a vacuum cleaner, get all the lint dust out of the motor, etc.
Cleaning may free the switch, and there should be a drawing showing how to put the belt back on, otherwise, make a drawing.
Posted on Nov 22, 2013
  • Scott James Shook
    Scott James Shook Nov 22, 2013
    Thanks I halve the part number for it on my wiring diagram. I will order it thiso weekend.
3 Suggested Answers
  • 53 Answers
SOURCE: dryer works only when push start button is held in
possibly the motor switch.
Posted on Jun 23, 2010
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
Ge dryer only works if start button is pushed in model #gtdx100emoww
The start/run switch on the motor is stuck, usually with lint. Clean everything with a vacuum while you are in there.
Nov 22, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
Jul 25, 2010 | GE DBSR453EBWW Electric Dryer
The stop button will not stay and makes a buzzing
This sounds just like you have a bad door switch. You check it by taking the two wires off of it and taping them together. Then try the dryer. It should take off and run normally. If so, replace door switch. Good luck.
Oct 21, 2009 | Hoover HDC6 Electric Dryer
Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
May 07, 2009 | General Electric DCVH640GJ Gas Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore Dryer
check also,
  • the other ends of all cables connected to the relay,
    if the other end of any part of the latching circuit has loosened, the relay will not latch closed when the start button is pressed.
  • Door Switch, it is part of the latching circuit
Sep 21, 2008 | Kenmore 62872 Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
150 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
