Question about ViewSonic VP2365WB 23 inch Monitor
Viewsonic vp2365wb flicker - ViewSonic VP2365WB 23 inch Monitor
Why is my mon displays for 1 sec then turns off
Check to make sure your computer is sending a valid timing signal to the monitor. Make sure the power cord is inserted and secure. Make sure the video cable is secure (no broken/missing/bent pins) and the input source is selected correctly. Otherwise, contact ViewSonic customer support for assistance.
Jun 07, 2014 | ViewSonic VP2365WB 23 inch Monitor
Tip
Viewsonic Monitor VA1912w
I just got a Viewsonic monitor with a flickering interference moving from top to bottom.  On examining the internal power board the capacitors CE101 and C200 were seen to be 'blowing'.  Replacing these 220uF capacitors restored correct operation.  I uprated the 2 capacitors to 105C 50V.
on May 29, 2014 | ViewSonic Computers & Internet
I have this model N3735w Viewsonic LCD flatscreen TV and it is flickering. The screen is also getting darker.
Try turning off the automatic brightness feature . This mode adjusts the brightness according to the light level in the room.
Dec 26, 2013 | ViewSonic N3735W 37 in. LCD TV
Veiwsonic VP2365wb backlight flickering
If it's not under warranty, buy a new one from newegg dot com.
Mar 27, 2013 | ViewSonic VP2365WB 23 inch LCD Monitor
Monitor wont display image. On power up the image flashes on for a second and then goes dark.
Sounds like an inverter problem, but before taking into a TV repair shop, check the connection at the power input socket, also try a different power lead
Jul 17, 2011 | ViewSonic VP2365WB 23 inch Monitor
Refresh rate for this monitor. Prefs. offer 60 or
Go for the highest your video card will allow to remove any flicker from the screen, or the max whichever works best.
I also have a Viewsonic Flatscreen, they are great and I had two Viewsonic CRTs before that.
Nov 28, 2009 | ViewSonic VA702b 17" LCD Monitor
Monitor Flickering and Sharpness control is disabled
it will probably be the graphics driver you need to update as XP probably loaded generic a graphic driver. The monitor should be ok with a standard driver.
Apr 18, 2007 | ViewSonic VA902B 19" LCD Monitor
ViewSonic VP2365WB 23 inch Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
