Question about Comcast XFINITY
Can i slow down close captioning? - Comcast XFINITY
  • 1,087 Answers
The Comcast set top boxes only allow 1 type of CC. However your TV is programmed to handle 4 or 5 CC features. Go into your TV menu and find your CC options there should be different ones there choice 1 you like.
Posted on Apr 03, 2015
Engage closed caption on my Aquos LC32d4u
Do you still have the original remote that came with the TV? If so, then down near the bottom of the remote you will see a button labeled CC for Closed Captioning. Click it and it should turn on your closed captioning. Hope this helps you out.
Feb 09, 2015 | Televison & Video
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
How to turn closed caption off?
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
Feb 01, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I turn on the closed captions
hi,
u can switch on the closed caption option for ur tv by the following setup.
1.Press the MENU button. Press the up or down button to select "Setup", then press the ENTER button.
2.Press the up or down button to select "Closed Caption", then press the ENTER button
3.Press the ENTER button to select "Closed Caption". Press the up or down button to select "On", then press the ENTER button.
4.Press the up or down button to select "Caption Mode", then press the ENTER button
5.Press the up or down button to select caption mode you want, then press the ENTER button. Press the EXIT button to exit the menu.
ok
Dec 22, 2010 | Samsung HLN437W 43" Rear Projection HDTV
Thank you for the help,for my insignia tv,ns-lcd32-09ca,to find the close caption,but beside that i have no manual,i also have no remote,i use the one for all remote and that works ,i still don't know how...
You can use the TV buttons to get access to close caption by pressing menu, volume up or down to select setup when you get to setup press channel down to close caption and use volume up or down to turn it on.
Let me know if you need further assistance.
Jun 13, 2010 | Televison & Video
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Can't get closed caption off of television
If you have the original remote use the closed caption button to turn it off. Without the remote, hold down both volume buttons on the front of the tv to bring up the menu. Use the the channel and volume buttons to navigate in the menu. Select the center icon at the top of the screen. Go down to closed caption. Select OFF. Wait for menu to go away.
Mar 05, 2009 | Sansui DTV3200 32" TV
Close caption works when I select the input for tv, select hdmi input and the close caption option disappears from the menu. I have a shaw cable pvr hd box and need the close caption to work on all...
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Jan 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Comcast XFINITY Logo
96 people viewed this question
Top Comcast Televison & Video Experts
Jay Plesset
 steve
steve
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
