Question about LG Refrigerators
Lg fridge model gr-s642aq won't stop beeping
Had new circuit board & controller fitted and we still have the beeps
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Posted on Feb 12, 2010
  • 93 Answers
SOURCE: alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Posted on Mar 01, 2010
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
When the fridge is turned on, it begins to beep constantly and does not stop until we switch it back off. We had moved the fridge about because we were shifting it to the kitchen and there was water...
HI, this beeping is signaling an issue that concerns the main control board. The control board may have sustained some serious damage during the move. Have it replaced asap. This spillage may have dripped onto the board itself, thus, causing a short when power was introduced after the unit was settled in its new arrangement.
You can visibly inspect the board for water damage or burn marks on the circuit layout.
Sep 30, 2009 | Hotpoint Refrigerators
My refrigerator LRSC26925 LG
Im afraid you may be having control board problems ... board can be found on top of fridge under plate where power cord enters unit .If your unit is out of warranty that board can be obtained through andrewselectronics.com or contact LGUSA.com for any customer service or warranty information. Unfortunatley that board is quite expensive. Try unplugging the fridge and replugging it to reset and press diagnostic button on the board
Mar 30, 2009 | LG LRSC26925 Side by Side Refrigerator
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
