Question about Watches
Removing back from stauer atomic watch - Watches
4 Suggested Answers
  • 2501 Answers
SOURCE: I want to send my atomic stauer watch for repair.
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Posted on Mar 20, 2010
escapement
  • 2334 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
cmcduncand
  • 714 Answers
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
How is a stauer notched leather watch band removed and replaced
No, he asked about a notched band, like on the Graves. Here the watch attaches not across the full 2cm or so but at two 6-7mm lengths around either side of a center protrusion, through which the pin slides.
Each pin consists of a longer part and a shorter end cap with a smaller pin maybe 2mm long that fits into the end of the longer hollow pin. These take a fairly serious pull to take apart, but must be pulled with care, for two reasons: one, so the pieces don't fly off and get lost when the pin comes apart, and two, so you don't accidentally torque the head sideways off the small pin, which is easy to do when you're pulling hard and not being careful. Vise-grips, with maybe thin wood like popsicle stick pieces to cushion the end caps might do, so you don't damage the end pieces as you squeeze, but again be careful. (If you do twist the endcap off its tiny pin, you might be able to glue it back with superglue (cyanoacrylate), but that's a patient precision operation by itself.)
Once the pieces are detached, the long pin will slide through the simple hole in the top and bottom protrusions from the watch case. You can customize your replacement band, set the pins, and gently compress them, again with widemouth pliers and a cushioning, they will go together more easily than they came apart.
Other Stauers use regular pins you can just pop off with the end of a pen knife, but this one is trickier.
Good luck :-)
Nov 09, 2010 | Watches
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
Aug 21, 2010 | Bulova Watch
How do you reset the time after changing the battery in a stauer 11475 atomic watch??
Take a look at http://www.stauer.com/pdf/17468.pdf
I see that this watch gets it's time signal from Boulder, Colorado so it will only work properly in North America. Perhaps they also do models for the European market - if so I would expect them to work in the same fashion so the manual should still be relevant.
Jul 29, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
GOTO:
r/ David
May 12, 2010 | Fossil Watch
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
Mar 20, 2010 | Bulova Watch
My Stauer Atomic won't stay connected to time signal
These watches only need to see a signal several times a day, not necessarily continuously.
If it keeps good time, don't worry about it.
Jan 05, 2010 | Watches
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
Oct 21, 2009 | Bulova Watch
My stauer atomic signal watch won't set correct time
Aug 08, 2009 | Bulova Watch
Watches Logo
222 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
