Question about Dryers
Maytag atlantis dryer
Dryer is squealing with a burning smell and drum is spinning
    Genius:
  • Dryers Master
  • 1,198 Answers
The belt is worn out. Have the whole unit cleaned, and the bearings checked.
Posted on Nov 22, 2013
SOURCE: Maytag dryer does not maintain heat and clothes smell
Save yourself the repair call and replace the gas coils. They're a $30 part and it takes all of five minutes. Works like a charm.
Posted on Oct 08, 2008
  • 2692 Answers
SOURCE: DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Posted on Jan 07, 2009
SOURCE: SQUEAKY DRYER
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Posted on Mar 31, 2009
Healeyman
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
SOURCE: My Maytag Atlantis MDG6400AWW will not heat up.
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Posted on May 04, 2009
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
TRY SPINNING THE DRUM BY HAND. IF IT SPINS EASY, YOU HAVE A BELT BROKEN.
MOST LIKELY THE BANG WAS WHEN THE BELT BROKE. YOU NEED TO PULL THE DRYER OUT, OPEN IT UP AND REPLACE THE BELT. A SERVICE APPLIANCE REPAIR WILL NEED TO BE CALLED. - - SORRY
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Atlantis gas dryer is making a sqeeling noise and sometimes will not turn the drum, unless i hand turn it and my run, i open it up but nothing looks out of order, the motor smells as if it is...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
It is making a horrible squealing nose when it runs and takes forever to dry. it is a maytag atlantis 7600 electric dryer.
The squealing noise you are describing sounds like the drum rollers in need of lubrication or replacement.
The problem with the drying could be a faulty heating coil and or faulty thermostats.
If your machine is a front loading machine:
Unplug the power cord to the dryer, remove the front of the machine, this will expose the drum and belt, then remove the drum and belt and this will expose the drum rollers.
Lubricate the shaft of the rollers with a good grade of machine oil like 3 in one Oil. If the drum roller is worn or have flat spots on them, then you may need to replace them.
Remove the back of the machine and this will expose the air tube, find the air tube from the blower to the drum, normally inside this tube you will find the heating coil and thermostats.
Good luck, I hope this helps
Oct 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Plastic wing inside the drayer drum fell
Replace the fin if you have found that it is broken.
May 27, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
SQUEAKY DRYER
Feb 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
