I accidentally turned off my sticky keys - Computers & Internet
  • Computers & ... Master
  • 5,124 Answers
If you have a Windows OS, the Sticky Keys option is part of the Ease Of Use Center in the Personalization Control Panel.
Depending on the settings for the Sticky Keys, you may be able to re-enable the feature by pressing the <Shift> key 5 times in a row. A pop-up will show up to ask you if you want the feature to be turned on. Click Yes. (The default option to disable the Sticky Keys is easy to hit - press two keys simultaneously on the keyboard.)
In Windows 7 and earlier, click Start > Control Panel (in the right hand column). Then click on Appearance and Personalization and then the Ease of Use Center. Scroll down to "Make the keyboard easier to use" and click that option. Check the option for turning on Sticky Keys. To adjust the defaults, click on the link for Set Up Sticky Keys. (In Windows 8, you can get to the Control Panel by pressing Control + X or by opening the desktop's Charms menu. Hover your mouse in the upper right corner of the monitor. Then when the menu opens, bring the mouse down to the Settings option (looks like a gear). Then choose Control Panel.)
I hope this helps.
Posted on Nov 22, 2013
Keyboard is locked
You haven't explained what you mean by locked but you may have accidentally activated Sticky Keys.
Go to Control Panel... Ease of Access... Change how your keyboard works.
See if changing the Sticky Keys option helps.
Aug 13, 2013 | Compaq Computers & Internet
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
How to turn off explorer sticky keys
In the Control Panel (Classic View), open the Ease of Access Center control panel. Follow the link that says, "Make the keyboard easier to use." Uncheck the box that says "Turn on Sticky Keys." You can also follow the "Set up Sticky Keys" link to adjust the Sticky Keys options.
Hope this helps!
Mar 10, 2011 | Microsoft Windows Vista Home Basic Edition...
I have a dell inspiron 1501 and my FN key is active all the time, so when I type any letter that have a number with it the number is what comes up not the letter, so in order for me to type the actual...
You may have (accidentally) activated the Windows "Accessibility" tools. One of the tools is "Sticky Keys". For example, people with impaired motor-skills can press CTRL, and then press ALT, and then press DELETE, to achieve the 'CTRL-ALT-DELETE' key-sequence.
Turn off "Sticky Keys". Or, restart your computer to start without the "Accessibility" tools.
Oct 22, 2010 | Computers & Internet
The Shift Lock is stuck in the CAPS position. When I turn it off it goes off CAPS but as soon as I hit the shift lock for caps which I need to do, I can't get it back to where I can type numbers, which I...
Sounds like the shift key isn't entering. Try both shift keys and see if one will turn the light off. If so tou need a keyboard rebuild. It may be cheaper to replace it.
DickyO
Aug 16, 2010 | Brother EM-530 Typewriter
I accidentally hit the shift button 5 times and
Hit the shift key again another 5 times to disable sticky keys.
Regards.
Jun 29, 2010 | Computers & Internet
Cant figure out how to get it off the little blue symbols
Either the "blue" coloured 'FN' is _stuck_ in the "down" position, or you have accidentally activated the "Sticky Keys" Windows "accessibility" tool.
With "Sticky Keys", you press keys just _one_ at a time, e.g., CTRL then ALT then DELETE instead of pressing multiple keys (SHIFT and '8') at the same time.
Restart, in order to turn-off "Sticky Keys".
Or, "exercise" the 'FN' key, until it "unsticks" itself.
May 07, 2010 | HP Pavilion dv4000/dv4200 Series Keyboard
I have acer extensa 5220 laptop, accidentally i split the cold drink on the keypad, now some of the keys are sticky, how could i clean it or i have to replace it
Remove the slim panel on top of key pad, remove teh screews, turn laptop upside down and remove the screws, carefully open the laptop right side up, remove teh keyboard and clean with a mild solution of warm soapy water. allow time to dry 100% and reinstall
Sep 30, 2009 | Acer Extensa 4620 Notebook
My msi gt729 when i phold down the w key after a
Sometimes keyboards have a setting (I think it is called sticky keys, but I am not sure) so that if you accidentally hold down a key for a while, it stops working to prevent you typing too many accidental letters. You can disable or adjust this in the keyboard settings.
Aug 23, 2009 | MSI Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
