Question about Cell Phones
Replace element in optimus space heater
Where can I purchase elements
Cara melepas mic k610i
Posted on Nov 22, 2013
Optimus LH-88 Baseboard Convection Heater - no heat
is that switch reading 0 ohms?, if it is, the triac has failed on the circuit board, if it is open then replace the switch. you can order a new circuit board from the manufacturer. of course you've checked to see that 240 volts is getting to the heater.
Mar 16, 2014 | Optimus Electric 30" Baseboard Convection...
Tip
DeLonghi Space Heater does not Heat
<p><b>Space heaters</b> are becoming more common as people are trying to get their<b> energy costs</b> under control. To try and s<b>ave money on heating</b>, many people are <b>turning down the heat</b> for their <b>central heating systems</b> and then heating just the area that they are in with a <b>small electric space heater</b>.<br /> <p><br /> <br /> <p>While these<b> electric space heaters</b> are relatively inexpensive, there are many people who want to repair their space heater if it stops heating. <br /> <p><br /> <br /> <p>If you have an <b>oil filled type space heater</b> and it is leaking or you are thinking of refilling it then check out this tip.<br /> <p><br /> <br /> <p><a href="/../support/r7770415-oil_filled_radiator_heater_leaking">Oil Filled Radiator Heater Leaking</a><br /> <p><br /> <br /> <p>If you have an <b>electric hot air space heater</b>, and it is not working, then there are only a few things that can go wrong. The only parts that can fail are the <b>switch(s) for the heating</b>, the <b>thermostat</b>, and the <b>heating element</b>. Of these parts, the <b>switches</b>, and the<b> thermostats</b> are replaceable, but the <b>heating elements </b>usually are not. Finding the<b> replacement parts</b> can also be difficult. Here is one website that carries many of the parts for these heaters.<br /> <p><br /> <br /> <p><a href="http://www.ereplacementparts.com/">Click Here</a> <br /> <p><br /> <br /> <p>To find out which part exactly is the part causing your problem, you will need to follow the power through the switch(s) and the thermostat to the heating element(s) and find out where and if the power is being interrupted before getting to the heating element. If the element is getting power then everything else is working and the element is bad. If there is no power there then go backwards till you find power and replace that part.<br /> <p><br /> <br /> <p>Always remember to mark any wires that you remove very well before removing them. There are many people looking for<b> wiring diagrams</b> because they have not remembered where they removed the wires from.<br /> <p><br /> <br /> <p>Also make sure to remove power, (unplug the cord) before removing any electrical components from the heater. Also when checking for power with the power on, you must be very careful to avoid a shocking experience that could result in death. Make sure all parts are away from metal parts of the heaters also to avoid shorting the part to the heater and blowing a breaker or ruining the heater.<br /> <p><br /> <br /> <p>In many cases, the time, energy and the <b>cost of parts</b> and shipping are not worth the <b>cost of the heater</b> that you are trying to fix. Make sure to check all of that out before trying to make repairs.<br />
on Jan 15, 2011 | Heating & Cooling
H-5300-bk
I have the Optimus quartz heater , model H-5300-BK . The top two elements are always on in the # 2 position , the thermostat only works on the bottom three elements. Question ; Can I removed the top two elements , so the thermostat controls the total heater. fredh@bresnan.net
Nov 30, 2012 | Optimus Heating & Cooling
Are the dimensions given for pool heater elements accurate?
The actual of the outer diameter canmeasure up to a quarter inch bigger than the measurements given. So take that into account when you are ordering.
Jul 16, 2012 | Optimus Element, Heater 4 Kw 1 1/4"npt...
How much will a new heater element 4Kw 1.25
Youcan get a new one for around $100. It's worth shopping around but here is alink for one site selling them http://www.spaandpoolsource.com/heaterelement4kw1141well.aspx
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Heater will not generate heat it oscolates and turns on but does not heat up ive only had this item for a few months
Unless, you have a different heater than the model number you listed in the title heading, it's an electric infrared heater. Not a gas heater.
There has been a problem with the heating elements on this unit. So, if you have your Proof of Purchase, you can return it for repair or replacement, because it''s still under warranty. Consult your Owners Manual/Guide, to find out the process for returning it to the manufacturer.
Hope this helps you.
Apr 19, 2011 | Optimus H4438 Gas Compact Heater
Holmes small space heater wire coil doesn't heat up despite doing the reset.
electric space heaters have a fusable link at the ends of the heating element that are a one time safety. If this is the case with your element, It will have to be replaced
Jan 07, 2010 | Heating & Cooling
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
