Question about Water Heaters
Electric hot water heater made a loud vibration type noise, followed by a bit of a power surge.
Just changed the top element today and the bottom one a couple of weeks ago.
    Master:
  • 571 Answers
Take an amp draw on each element while they are on.
Posted on Dec 21, 2013
Have power at top element but not bottom
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) Upper element is good because you have some hot water.
Circuit breaker and power to water heater are probably good.
Step 1: Test lower element. Replace if needed.
Next step, If lower element is good: Replace upper and lower thermostats.
Jan 06, 2013 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
I have a Reliance 606 water heater that no longer provides hot water. Any ideas?
the heating element has most likely burned out (if its electric) if its gas then look to see if it is lightinng. if electric, the element is easy to replace and not very expensive.
Mar 11, 2011 | RELIANCE ELECTRIC WATER HEATER
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
My Reliance water heater suddenly produced only luke warmwarm water. I checked for power to the elements. Top one had nothing, bottom one had 110. I replaced the top element (which looked ok.) (power...
Lower element will always test 120V to ground since thermostats turn off one hot wire.
Listed below are suspects in order of ease.
1) Check that hot water is not running out of TP valve and down into a drain.
This will cause water heater to run all the time but not be able to keep up.
2) Test elements before replacing anything:
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) Test electricity to water heater:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Replace both thermostats.
5) Final thing would be full troubleshoot:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 29, 2010 | RELIANCE ELECTRIC WATER HEATER
We had no hot water so we check the elements with a voltage meter and found the bottom element to be bad. We replaced it. Now there is still no hot water. When we test the voltage again there is continuity...
The elements never run at the same time, it would take to much energy for a standard residential heater. Instead, they rotate powering up back and forth depending on the hot water demand. If you getting 208 to 240 volts on the top element and nothing is happening, the top element is bad and needs to be replaced. If you can swing 30 bucks, replace both elements and both thermostats at the same time. This way you know that everything is new. Check out this generic water-heater wiring schematic.
Sep 06, 2010 | Reliance & 50gal Electric Water Heater
Sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Wiring for dual 30 gal heat element. changed both elements. need to put wiring back
Go to this link and page down, it gives you the wiring diagram for a dual element hot water heater.
http://www.plumbingsupply.com/element-installation-instructions.html
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Element Water Heaters
50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
Dec 01, 2009 | Reliance & 50gal Electric Water Heater
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
