Question about Yamaha 2003 Yz450f Yz450 Yz Wr 450 Stator Stater Electric Generator Voltage Pulse Coil
2003 yz450f too lean backfiring on deacceleration
Yz450f running lean. got a 50 pilot jet and airscrew almost all the way and its still a little too lean. shouldn't need any bigger than a 45 pilot jet. replaced intake boots/joint and got a new air/fuel screw
  • 125 Answers
Clockwise is rich & cc is lean which way are you adjusting?
clean the small air port in carb with adjustment screw removed.
Screw should be set 1 1/2 turns fron light seated position.
Posted on Nov 22, 2013
Testimonial: "yes it shouldn't be anymore than two turns out. it only stops backfiring when the screw is about 4 turns out. I took the carb apart and sprayed carb cleaner through all the ports. I should only be running a 46 at the biggest with about two turns out but its not working out"
Wont idle on its own
Hi, Anonymous and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2010 YZ450f starts but soon stops bike stalls FOUND ANSWER
2007 2013 Yamaha YZ450F Service Repair Workshop Manual Download Manuals...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 01, 2014 | 2007 Yamaha yZ 450 F
2003 yz450f running too lean
First, try to avoid ethanol. It melts carb lines, and can goo up small passageways. Get some good gas and try again. Hi test if necessary. Check your specs, maybe the bike requires hi test.
Taking apart and cleaning involves soaking in fresh carb solvent to clean the small passageways. Is there an air cleaner? It may be clogged, test with it off.
Nov 22, 2013 | Motorcycles
2003 yz450f popping on deacceleration too lean
wots the colour of the plug after its had a good run? is the exhaust gasket on the head leaking as this can cause this ? have you coated the air filter with a film of oil as this is required and also stops dirt passing through it ? correct spark plug and gap ? timing set correctly ?
Nov 21, 2013 | Yamaha 2003 Yz450f Yz450 Yz Wr 450 Stator...
Will not idle without choke
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
05 yz450f wont idle must run by friday YZ 400 426 450
Wont run without the choke yz450f 03
YAMAHA YZ450F Owner Service Manual
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jul 21, 2013 | Yamaha YZ 450 F Motorcycles
I have a yz450f 06 and its not running right its spluttering and poping on take off and cruizing at low throttle.
clean plugs, is the smaller jet blocked. is vacuum pipe to tank leaking anywhere.
Mar 11, 2013 | Motorcycles
Fork oil capacity for 2003 yz450f
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2003 YZ450F Fork Oil Change
How much goes to 2004 YZ450F forks
Yamaha 2003 YZ450F Owner Service Manual
Feb 26, 2013 | 2008 Yamaha yZ450F
05 YZ450F wont idle just not sure how to adjust the idle?
Hi, Bryce and the usual suspects are:
04 yz450f wont idle NEED HELP
06 YZ450F Wont Idle
Jun 25, 2012 | 2004 Yamaha YZ 450 F
I was riding my 03 yz450f and it back fired and just died. then i tried to start it had a hard kick and had to use hotstart to start it once started ran 2 seconds and backfried and died. then tried...
hi mate backfire usually points to lean fuel condition but in your case being quite severe maybe blocked pilot jet. I would remove carbi and compress air clean it with pilot jet out and clean or replace pilot jet they only cost a few dollars...
I would also highly recommend a leak down test to double check your valves are sealing well and compression is all within range.
any Yamaha shop can do this test for you if you don't have the equipment, may be hundred or so but could save you heaps with accurate diagnosis in case something major is wrong??
regards Jamie
Jul 24, 2011 | 2003 Yamaha YZ 450 F
I have a 2000 ktm520 it keeps backfiring as soon as soon as i let off the throttle with the choke off it fine with it on I tried to blow out the lines they all seem fine.it was sitting for about a year I...
This back fire is result of lean pilot circuit (pilot jet) causes are most likely partial blockage to pilot jet -change in weather condition also happens quite often when a new exhaust system are fitted??
I would fist change the pilot jet to a new one they only 5 - 10 dollars to buy so not expensive
If you 100% your pilot is clean already then you need 1 or two sizes bigger pilot jet to get rid of backfire
all bikes are different of course but generally speaking hearing a pop or small backfire every now and again is normal on de- accelleration if it is excessive then its to lean but if you never have any pop or backfire ever then chances are it may be to rich so smaller pilot jet required
good luck mate hope this helps a little regards Jamie
Jun 19, 2011 | KTM MXC 520 Racing Motorcycles
I have a 2004 yz450f and am having a hell of a time getting it to run right. I checked all of the resistances on the electrical system and they are good, but it doesn't seem to be getting a strong spark. ...
Hi, Spinmanbob and the usual suspects are:
Motor bogs when stab throttle
2008 yz450f bogs when throttle opens YZ 400 426 450
Jun 12, 2010 | 2004 Yamaha YZ 450 F
Yamaha 2003 Yz450f Yz450 Yz Wr 450 Stator Stater Electric Generator Voltage Pulse Coil Logo
148 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
