Question about Invicta 0362 Russian Diver GMT Mens Watch
I replaced the battery but the watch does not run
My Coifman sc0170 has stopped working , I've only worn it 6 or 7 times i bought it in March 2016 , after wearing the watch I always put it back in its box any I dears plz
I see that this is a quartz chrono. Firstly, make sure that the crown (winder) is fully pushed in. If you have had the chronograph function running all the time, this will deplete the battery quite quickly. Also, when you buy a watch, depending on where you bought it, it may have been running for some time perhaps as a display model so the battery might already be well used.
If pressing the crown in doesn't sort it, get the battery replaced. If that doesn't get the watch running then you should return it as faulty (as it was a very recent purchase). If battery replacement does get the watch going then you might want to read the manual to ensure that you're not constantly running the chrono function, which will seriously reduce the battery life..
Jun 05, 2016 | Watches
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
Fossil AM-3539 The watch has 2 batterys. one operates the changing face the other the watch movement. I replaced both batteries and now the face doesn't change. How do I re-set it?
Please note that many Fossil kaleido watches, especially the sports variety actually have THREE batteries. Two run the animation and one runs the time. The time one lasts much longer, usually a few years, but is smaller and buried a little deeper so you could overlook it if not paying attention. The two kaleido batteries are very visible and usually placed side to side. Pay attention though as for some of the watches those two batteries are set in the same way ( both positive sides up) while others, especially the sports variety have one battery positive side up and the other negative side up. It is important to replace them the same way or the watch will not work
Aug 12, 2011 | Watches
Right side of the watch is working, but digital(left) side is not. Is this out of battery?
This watch will most likely run on two batteries - one for the ana and one for the digi. Usually the digi will run out faster if you have an alarm or lamp on it. When you replace the battery always use top quality swiss or german made batteries. Use Renata, Rayovac or Varta as a preference.
Sep 20, 2010 | Fossil Analog Digital Wood Watch JR9309
Seiko 5m43 fails run after cell replacement
Hi, Look on page 11 of your manual for the proper procedure to restart watch after a battery change, or complete discharge of capacitor system. If you don't have the manual, Try this link:
http://www.seikowatches.com/support/ib/index.html
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 08, 2010 | Seiko Kinetic watch
How to set the clock how do i no the battery good just got it
If the watch is not running it's probably the battery. To set, pull the crown out and turn to adjust the time. Push the crown in to run the watch. If the watch is new the battery should be OK but take it back to the store if it doesn't run. If you bought it used take it to any watch shop for a battery replacement. Sears does it for about $8 or less.
Apr 28, 2010 | Movado 0604771 Wrist Watch
The watch is not running after replacing the battery, the stop watch part is running.
It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
Clean also the watch contacts.
Feb 03, 2010 | ESQ 07300902 Wrist Watch
I have replaced the battery, but it didn't work. I've tried to reset the watch, but it didn't work. What have I to do to reset the WV-57H after a battery replacement?
If your watch has any kind of illuminated dial or dial light, you may have found the battery for that instead of the one powering the watch itself. I have one similar and did that same thing only to find that the watch still wouldn't run.  The battery that powers the illumination is larger and in my watch, the battery for the watch portion is half the size and located below and to the side of the other cell.
Mar 09, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Timex electric and dynabeat wrist watches
Good day Sir, If you own a Timex and it seems to be running a little slower than usual, visit the link below for their manufacturer watch battery replacement services.
replacement batteries
Mar 13, 2008 | Timex 27191 Wristwatch
Invicta 0362 Russian Diver GMT Mens Watch Logo
19 people viewed this question
Top Invicta Watches Experts
Jimmy Accardi
Geoff
Are you an Invicta Watch Expert? Answer questions, earn points and help others
