Question about Invicta 0362 Russian Diver GMT Mens Watch
Battery replacement I replace the battery but the watch does not run
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
The watch is not running after replacing the battery, the stop watch part is running.
It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
Clean also the watch contacts.
Feb 03, 2010 | ESQ 07300902 Wrist Watch
Need help replacing battery in my nike Imara Womens watch? Which way does battery go in with plastic cradle?
1. Use a coin turn the battery hatch one-quarter turn counter-clockwise
2. Remove old battery from compartment. Keep plastic cradle and replate with 395/SW927R battery. Replace the new battery positive side facing up in the plastic cradle into the metal compartment in the watch. Ensure all three little tabs line up and twist cradle to lock into place. Make sure the O-ring is in proper placement on the cover and replace the battery hatch ensuring it is sealed completely!
Jan 28, 2010 | Nike Imara Run WR0075-014 Wrist Watch
New watch not working
I would go and get the battery replaced. Watches will run off the battery even when sitting on the shelf in the stores. Replacement are usually less than $10 at the mall or check a jewelry store.
Jan 21, 2010 | Kenneth Cole KC1232 Wrist Watch
My 92 yr old neighbor had her battery run down on her ''On-Time'' atomic watch. I replaced the battery 4 days ago and it has not reset the time. I am located in Muncie, IN. and the watch worked prior.
No reason to panic. First - replace the battery for another one, as the one you fitted can be on low. After replacing set the time manually. Within few days watch will start to receive signals and will reset itself to correct time.
Rate me plz.
Jan 08, 2010 | Watches
Time display does not stay on,I have to push light button
This can occur for many reaons. There could be a movement problem. But it can also be the battery is running slow. If the battery was replaced recently it could be that it needs to be resett. When the battery is replaced on most digital watches the battery and the AC of the watch need to be shorted.
Aug 11, 2009 | Casio G2310-1V Wrist Watch
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
How to replaced a eco drive battery
The ECO series of Citizen's do not require battery replacement, as they are solar powered. If the watch stops due to a long period of non-use, there is a procedure in the manual as well as the Citizen website on how to get it running again. You will have to expose it to light for several hours (but not with lots of heat such as a car dash) to get it running. If you continue to have trouble, you may have a problem with the watch. I bought my wife a ladies ECO drive about 8 years ago and bought one for myself about 2 years ago and have not had a bit of problems with either. They are extremely good watches and it is nice not to have to worry about "when will the battery die?"
Jul 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Timex electric and dynabeat wrist watches
Good day Sir, If you own a Timex and it seems to be running a little slower than usual, visit the link below for their manufacturer watch battery replacement services.
replacement batteries
Mar 13, 2008 | Timex 27191 Wristwatch
Invicta 0362 Russian Diver GMT Mens Watch Logo
27 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
