Question about Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Service Manuals lsr5100kqo
Remove tub
Whirlpool calypso washer tub shakes and rattles
whirlpool , simpson , westinghouse are all in the same manufacture house
you problem sounds like the tub suspension rod air dampers have failed
replace these rods and the tub is more stable
at the bottom end where the rods go through the mounts is a plastic cylinder that has a moving piston and spring inside ' the tip section of the plastic breaks free and then there is no air dampening effect
you will have to remove the top of the machine to get to the upper ends to replace the rods
cosy for 4 rods is around $90.00 AUD and can be got from the service agent spares
May 07, 2017 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool top loading washer, LXR9245EQ2, quit agitating, spinning and makes a clacking noise, pump looks like it's still holding the water in the tub though and won't pump out?
There are two clips that hold the pump to the motor, remove it and inspect, turn pump axle in either direction. If not replace the pump. However if you remove it you may find a sock or something in which case you can remove item and put back into service. If jammed you need to replace with a new pump. Good luck, masta tech
P.s.if water remains in tub it has something blocking it, be ready to capture any water in tub when removing hose clamps. If it a small amount you may be able to just lean it backward to hold water.
Aug 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
The washer cycle stops with 26 minutes remaining in the cycle and will not drain the water
Can you lay the hose on the floor and get water to come out? If not then ya themobilian_2177.jpg
might have a problem with an object blocking the pump. To get into the machine
remove the whirlpool emblem in the front and you will find a screw. Remove it and the top comes forward and up. themobilian_2178.jpgthemobilian_2179.jpg
Raise up on the front panel after removing screws, the base has clips like a dryer.
The tub is suspended on four rods like a ge washer. Remove the drain hose and unplug the motor, the tub comes out of the case
It is not very hard to work on. You could have something between tubs.
This one had a big old pillow case between tubs
I have the service manual HERE and more photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
It's making a very loud banging noise in spin cycle
There can be any number of reasons for the tub slipping / jerking.
First, see the Sears parts site for your washer:
http://beta.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=11092584100&productCategoryId=0153200&brandId=0582&brandDescription=KENMORE&modelName=WASHER&searchedModel=110.92584110
and you'll see a list of major sub-components with diagrams and parts.
It's possible that the drive block and / or tabs holding the tub to the block are worn / damaged.
Also see the Whirlpool / Kenmore Service Manuals for these washers:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
I'd essentially pull the washer apart to check that everything is in place.
(IT'S NOT AS DIFFICULT AS IT MAY SOUND AND MOST FIXES ON THESE WASHERS AREN'T VERY EXPENSIVE)
See the following for a detailed description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=75a4070beeb01ac4cd6c732ff4f740fc
NOTE:
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
The problem does point to the drive block and/or the nut holding the tub to the block. The block is soft metal and easily damaged if the nut isn't tight. Also check the tabs on the tub to make sure that they fit into the notches in the block.
Jul 24, 2010 | Kenmore Washing Machines
I have a kenmore elite washer mod.#110-27062602
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27062602&pathTaken=partSearch
Assuming that this is the Oasis type washer, see the Whirlpool Service Manual for their Cabrio washer which is basically the same as the Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and teardown procedures.
May 08, 2010 | Kenmore 22422 Top Load Washer
Are there written instructions on replacing tub gasket for GHW 9100lw Whirlpool front loader
I am not aware of any step-by-step service manuals online, but see if you can figure it out from the diagrams here. It should not be that complicated.
Aug 23, 2009 | Whirlpool GHW9100L Front Load Washer
I cannot remove the basket from the tub.
i am a maintenance man at U OF I and need to change the tube seal on this washer but dont know how to remove the ajatator btoolmanA illicom.net
May 12, 2009 | Whirlpool LCR7244H Top Load Washer
Loud knocking sound
You have a bad drive block. This block is located under the inner tub. A special spanner wrench is required to remove the tub. You really need to call a service tech for this repair.
Apr 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
