Question about Vizio Tablet VTAB1008
Why won't the battery charge?
Battery will not charge up, battery comes up on screen when connected to charger but never charges, battery stays looking empty on screen.
    Problem Solver:
  • 17 Answers
3 logical possibilities comes to mind: 1) Battery is faulty. 2) Charger is bad, not connected to an active wall outlet or not making good connection with the tablet. 3) There is a software issue, possibly with the application that shows the battery status.
Posted on Nov 21, 2013
  • londi_m Nov 22, 2013
    you should check the head of your charger where it pluvs in alot of times they intend to breka the wires inside and it will not give any contact to the plug to pas the electricity so check the pin
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Sep 19, 2012 | Nikon Coolpix 4100 Digital Camera
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
My LGIP-430N won't hold a charge. I put it on the charger for a long period of time (5 hours) and it only has one bar in the battery indicator. I don't understand why it won't charge up and stay charged....
Ifthe cell battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 24, 2011 | LG Cell Phones
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
The phone won't take a charge. The red light comes on indicating that it is charging but it doesn't. What's the deal?
Try this.. as it works for me on my GzOne Rock..
Connect to the charger just long enough for the screen to power on, then immediately disconnect the charger before it goes into charging mode. . -- It should power up and be ready for use.in a couple seconds.
I have found that only when the battery gets completely drained, that the Gzone Rock often will not power back up on it's own, even though the battery has been successfully recharged.
By connecting the to the charger it will initiate the boot-up of the phone - but you must remove it before it displays the charging screen again, otherwise it still won't come on and boot.
I don't know why, but this method works for my GzOne Rock every time.
Jan 31, 2011 | Casio G'zOne Rock Cell Phone
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
I have a question concerning the tomtom 910. When plugged into the car, the tomtom goes off and on and the battery is constantly low. However,when I charge it at home, it stays on for about 4 hours. What...
Connect your TomTom to the car charger and turn it on. Tap the lower right hand cornor where the sat. signal graph is. On the screen that comes up check to see if it is chargeing while connected to the car charger. It should say charging in the upper right hand cornor where it shows the battery status. If it isn't charging then you have either a bad pin on your windsheild mount or your charger is not working. If the charger is not working it may be as simple as replacing the fuse in the charger.
Jul 19, 2009 | Tomtom GO 910 GPS Receiver
Vizio Tablet VTAB1008 Logo
258 people viewed this question
Top Vizio Cell Phones Experts
Computer Repairing
Computer Repairing
ray gallant
john Benson
john Benson
Are you a Vizio Cell Phone Expert? Answer questions, earn points and help others
