Question about Panasonic LUMIX DMC-TS20 Digital Camera Blue dmc-ts20a Norman Camera
Camera not powering up after battery installed. After inserting existing or new battery, camera indicates "This battery cannot be used" and will not power up.
Both batteries indicate fullly charged
  • Keith Schafer
    Keith Schafer Nov 27, 2013
    Thank you for those comments. Still no joy. Battery voltage is good on both batteries, new and old. Cleaned contacts. This is a Panasonic Lumix DMC-TS20 Digital Camera. There is no USB, mini or micro, on the camera or charger.
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
The charger can tell the voltage is high enough, but still not sure the camera will work. Did you check ale contacts also the ones in the camera, are clean and shiny? Only a little spec of dust, can give you lots of trouble. To be sure the batteries are both ok, use a multimeter and check the voltage. On the multi meter the voltage should be just a few tenths of a volt higher than what is printed on the battery. I think your battery must be 3,7 Volt, so at least 3,8 volt should be measured, because the multimeter does not take any current from the battery. My 3,7 Volt Kodak batteries, still give 4,03 and 4,07 volt, three months after they are charged. Those are Li-ion batteries.
As soon as they give less then the printed value just after charging, you know they are not ok anymore.
Posted on Nov 27, 2013
Testimonial: "Thank you for those comments. Still no joy. Battery voltage is good on both batteries, new and old. Cleaned contacts. This is a Panasonic Lumix DMC-TS20 Digital Camera. There is no USB, mini or micro, on the camera or charger."
I am trying to to charge panasonic lumix dmc-zx1 camera battery with it. As soon as I plugged it in showed a red light (power) on the charger. Even after inserted the camera battery the the red light on...
IF YOUR CAMERA USES AA OR AAA BATTERIES...TRY USING REGULAR BATTERIES, YOUR CAMERA BATTERIES MAY BE BAD AND NEED TO BE REPLACED.
HOPE THIS HELPS!
Aug 31, 2011 | Cameras
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
We insert new batteries and they last seconds, any
Please confirm me first, after buy the new battery did you charged is 6 hours? If not then charged it first and use & you see the problem will gone. If till same then you need to replace the camera power condensor. That must be damaged & can not take the power from the battery. Thanks.
Mar 10, 2010 | Kodak ZD710 Digital Camera
My Kodak digital camera's shutter is stuck on open & it will not stay turned on. Camera does not indicate a low battery, just charged.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 02, 2009 | Kodak EasyShare M1033 Digital Camera
Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Apr 15, 2009 | Samsung Digimax A6 Digital Camera
Camera just froze up.
Try Rebooting the camera. Take out the existing batteries and insert some new ones. Then, turn it on and the lens should go back inside!
Hope this helps.
Jan 29, 2008 | Canon PowerShot A75 Digital Camera
When a camera is inoperable or fails to function, or an error code appears in the liquid crystal display (LCD)
Follow the steps below in the order presented: Perform a power reset on the camera. Performing a power reset on the digital camera will normally correct issues such as the camera locking up or not turning off. When the power reset is performed properly, the camera will prompt you to update the camera’s date and time. This is an indication that the memory has been cleared and no further reset time is required. The power reset procedure must only be performed on a camera that has been running on battery power. If an AC power adapter is being used, the power reset procedure does not apply. This is due to the fact that the internal capacitor is fully charged. To execute a camera power reset, perform the following steps: Turn off the Digital Camera. Remove the Compact Flash Card or Secure Digital Card, if one is being used. Turn on the Digital Camera. CAUTION: To avoid damaging the camera, ensure the shutter button is not pressed during the following steps. Turn on Live View on the rear LCD. CAUTION: Care should be used when performing Step 5 to ensure that the camera is not dropped. Open the battery door and remove the batteries with the camera turned on. Re-insert the batteries after five minutes have elapsed. Turn on the camera. The camera should request an update for date and time (with the exception of the HP Photosmart 120 and 912 series cameras). Format the memory card. Navigate to the delete menu which varies with each camera, and format the internal memory and/or the memory card. CAUTION: Reformatting the memory card erases all of the files that are stored in the card. All photos, scripts, and miscellaneous files are deleted permanently. To preserve the existing images, use a spare card or a card that is already formatted.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Panasonic LUMIX DMC-TS20 Digital Camera Blue dmc-ts20a Norman Camera Logo
43 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
