Question about Thermador SMW272 Electric Double Oven
Light in control panel is out
Light out in control panel
    Champion:
  • Thermador Expert
  • 320 Answers
Need new display/relay board kit.
Posted on Feb 05, 2015
Do I have to replace the control panel on the oven if it isn't lit?
Without a full schematic, and an understanding of electrical wiring, you have no idea if the internal 120 vac light is even on the same circuit as the control panel. Electric ranges are generally powered by 220vac, which means that both 120 lines are run through the unit.
you could have full power to the appliance bulb and have a blown fuse to the control panel, how much of the range actually functions at the moment would be important information to share.
Mar 04, 2015 | Whirlpool Gold 30 in. Double Electric Wall...
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
Oct 23, 2011 | Whirlpool Ovens
The control panel light is very dim. It is hard
we had the same problem....my husband removed the panel and I clean the inside glass panel & it resolved the problem. It is a convection oven and steam comes out just below the clock area which I believe causes the problem.
Jul 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Control panel doesn't light up
HI, this issue concerns the touch pad(control board led). This will happen in certain models. it could be some minor corrosion within the wire contact clips that are not allowing the proper current to illuminate the led that is used to light the specific button or, it could be a minor circuit issue within the control board as well.
i recommend inspecting the control panels wire harness contact clips that are behind the actual control board. make sure they are not corroded or lose. if they are lose or corroded, i suggest replacing the entire wire harness. this could be the possible reason for some of the lights that are not illuminating during operations.
If the wires and contacts are in good condition and the harness is in good condition as well, this could be an internal control circuit board issue, concerning the LEd lights. they may have burned out due to the age or heavy usage.(heat related)..
Please rate and god bless:)
Apr 20, 2009 | Electrolux 30" Built-In Single Electric...
Control panel light problem & clock setting
Hi
to change the light tube and starter you need to remove the front control panel by the screws underneath it and at the side the yo can get to the light for the clock just press the first 2 buttons on the left and either + or - hope this helps you
regards
Mar 18, 2009 | Ovens
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
OVEN LIGHTS DO NOT TURN OFF.
The oven has a small button on the left side on top of the control panel. Switch it on or off. Hopefully this will solve the problem.
Nov 09, 2008 | Frigidaire 30 in. Electric Gallery Series...
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Thermador SMW272 Electric Double Oven Logo
77 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
