Question about Cell Phones
Touch screen calibration
I cant calibrate my screen and its way off when texting it keeps putting an "n" instead of "m" for example its driving me bonkers........I cant find the screen calibration menu on my casio c771 HELP PLEASE
SOURCE: touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Posted on Jan 23, 2008
SOURCE: p990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Posted on Sep 17, 2008
SOURCE: The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Posted on Dec 24, 2008
SOURCE: cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Posted on Jul 26, 2009
jonniewalker
  • 1029 Answers
SOURCE: How do I calibrate my touch screen
Calibrate the g1 touch screen on the device by going to Start>Settings>System Tab>/Screen then Click Align Screen If you cannot get to the Screen Alignment utility using the menu’s, it can also be accessed by pressing the Volume Up and Center Navigation Buttons at the same time.
hope this helps, pls appreciate by rating as fixyaa
Posted on Jan 13, 2010
TOUCH SCREEN TOO SENSITIVE KEEP MAKING CALLS WHEN I ONLY WANT TO SCROLL DOWN SCREEN
Hello Eda,
You can resolve the problem by increasing or decreasing accuracy on the keyboard. Press MENU on the Home screen > Settings > Language & keyboard > Touch Input > Text input > Calibration tool. Tap the given phrase and after you have completed the calibration, the keyboard should be more attuned to your touch screen habits.
Jun 18, 2011 | HTC Wildfire Cell Phone
Calibration for 8060 touch panel
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
May 05, 2011 | Panasonic Workio DP-3530 Copier
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
The touch screen doesnt work propley if i press for example 4 the * key gets pressed.. its jusst not write i cant even check my text please help me out.
try looking for the pen calibration in the settings menu, after you have located it perform what is said on screen, just follow the instructions, if that doesnt work, it means that your touch screen has physical damage already and the only thing you can do is to replace the lcd assembly.
Jun 01, 2010 | LG KP501 Cell Phone
Touch calibration not working...... keeps saying invalid calibration and touch screen itself is jacked up
i got the lg xenon for christmas.. and everytime you turn it off and power it back on you have to do the touch calibration and you do it once exaclty in the center of the cross and then any other time it asks just put dots randomly anywere and when it says save press no .. so you will have the first good calibration saved (:
Dec 11, 2009 | LG Xenon GR500 Cell Phone
Cant calibrate screen on i900 omnia.
Jul 22, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My Ming Xing A008 is having some problems with the touch screen. When ever i click an icon it will click on the icon to the right of it instead and its like that when everything. I have tried to do the pen...
when u do the pen calibration make sure u dnt just tap da screen with the pen ,tap on the center of da "PLUS' logo on the screen ,mine takes abt 5 to 6 rounds of calibration.
May 01, 2009 | Cell Phones
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
