Question about HP LaserJet 8150n Printer
HP 8150 LaserJet E10 1 ERROR - HP LaserJet 8150n Printer
eagle338
  • 4889 Answers
SOURCE: Hp Laserjet 8150 LVPS replacement
It is located in the back of the printer on the bottom. Remove the back cover. With the power off, remove the formatter board by loosening the two big screws and pulling out. Remove the plastic cover by the side of the formatter cage. Remove the fan housing by the power connector by removing the two screws, disconnect the cable and pull straigt out. Now remove the big cable at the top and unwind from the high voltage ps. Remove the white connector in the middle of the low voltage ps. Next trace the white cable wires running from the ps to the dc controller and remove the cable from the dc controller. Now trace the fan cable for the fan in the front of the ps and remove it from the dc controller. Remove all the screws which secure it to the frame and pull straight out. Move the fan in front from the old ps to the new and reverse instructions...
Take off the large metal side cover. Look down at the bottom of the printer. The large box is the LVPS. Remove the screws holding it and follow the wiring up to where it plugs in and pull the connectors off. You'll also have to remove the fan above the LVPS on the top right side of it. You will have to take the fan mounted on the LVPS off and put it on the replacement LVPS as they don't come with fans.
Posted on Oct 23, 2007
  • 81 Answers
SOURCE: hp laserjet 8150 printer jams from tray 3
I would recommend replacing the PIU paper Input unit on the printer.Having repaired several hundreds of these printers this always rectifies these feed proble. The clutches can go weak as can the paper tray lift mechanics
Posted on Oct 13, 2009
  • 83 Answers
SOURCE: hp laserjet 8150. i have a problem, tray 3 empty,
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Posted on Nov 25, 2009
seeker5211
  • 1089 Answers
SOURCE: Hp Laserjet 8150.
Start by pulling out tray 2 and setting it on the floor. Next take out tray 3 and slide it into tray 2. Print from tray 2. If it works, take the tray on the floor and put it into the tray 3 slot. Print from tray 3. If it fails change the feed rollers.
Posted on Jan 24, 2010
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
I have a HP LaserJet 5000 with a Fuser Error code 50.1, meaning low temp. I am not a tech, but I have been repairing my own cars, printing presses, computers, printers and anything else that breaks for over 35 years. The previous fuser on my LaserJet 5000 lasted over 7 years and while I was not getting any error codes, it was not fusing laser plates as well as I liked. Until recently I had two HP 5000 LaserJets and was able to trouble shoot by swapping parts. I replace a bad DC controller board in this particular printer about a year ago. Shortly after that I replaced the fuser with a genuine OEM HP fuser and it fused great for nearly a year. A few weeks ago I had a massive paper jam in the fuser and a day later got a Fuser Error 50.1. After checking the Internet I determined it might have broken the ceramic heating element. I swapped fuser with the one in my other identical working printer and the fuser error went away. I swapped the fusers back again and the error returned, pretty much proving the problem is in the fuser. Since I am not made of money I figured I could rebuild a fuser just as well as anyone else so I went on a search for the parts, but it was like calling Area 51 and asking what they were hiding. The service manual indicated some ohms testing to be done on the problem fuser and all results came back showing all the correct readings. I knew the fuser was the cause of the error, and the parts were not cheap so I carefully disassembled the fuser to see if I could isolate the exact part that was broken. The ceramic heating element and everything else looks fine. One detail I had found odd was that the printer used to take a couple of minutes or more to heat up, but I now got the fuser error 50.1 within 15 or 20 seconds of powering it on. This made me wonder if it would even have enough time to heat up enough to know it had a low temp problem. I thought the problem might be in the part that actually measured the temp. While I had the fuser apart I found one small resistor attached to the frame directly under the main drive gear. I did an ohms test on the resistor and it showed bad. I really hate to tear my good fuser apart to swap the resistors for fear I might burn it up to, so has anyone out there heard of a bad resistor causing a 50.1 error? I found only one reference on one site about a different LaserJet with a 50.1 code because of a bad resistor, and I have no idea where that resistor is on that particular printer. I know I could have just replaced the fuser by now, but I like to learn how things work and solve puzzles like this one. I am hoping some of my info may be of help to someone and if anyone has anyone ideas or thoughts on my comments, I would love to hear them. I will go on a search for a resistor next week and see if that helps. I hope to hear from someone soon. Thanks and God bless. James
Posted on Mar 08, 2010
62.0 error
62.XX error
There is a problem with the printer's memory. The x value refers to the location of the problem:
0 = Internal memory
1 to 3 = DIMM slots 1, 2, or 3
Recommended Action
Reseat or replace the specified
DIMM
It might also be the formatter but start with reseating the DIMMs
Dec 04, 2013 | HP LaserJet 8150dn Printer
What Causes an EIO 2 Error 82.0180 on an HP 8150 LaserJet Printer?
Usualy that is an JetDirect card error. Try with another JD card.
May 25, 2012 | HP LaserJet 8150 Printer
HP 8100 dn error code of 57.5 comes up, power cycle down does not fix the problem
HP LASER PRINTER 8100, 8150 ERROR 57.5 code
1. The fan 1 or the laser/scanner fan has occurred.
2. Replace fan 1
3. Replace the D.C. controller board.
Try reseating the connector to the fan, it may have worked loose.
May 18, 2012 | HP LaserJet 8100dn Printer
HP 8150 error code of 57.5 comes up, I cycle power, I have checked all the cables and still comes up with error code. Does anyone have any suggestions?
Hi
Error code 57.5 in HP 8150 means that printer fan error has occurred with the power supply fan. This issue can also be due to laser/scanner fan. Make sure both the fans are working perfectly fine. If the fans are fine, then the error is due to DC controller board.
To resolve this error turn off the printer for 4-6 hours (atleast 4 hours), this will reset the error. However, even after 4 hours you still can see the error then please check and replace the fan1 (power supply fan). Also, check for any burnt components on the dc controller board.
Daniel Scott
Jun 18, 2010 | HP LaserJet 8150 Printer
I cont create ip in 8150 pls give me instruction to create ip
You can go to the configuration menu, then look for network config. or network parameters, if ask you for dhcp or manual select manual (or static), then it;s gonna ask you for the ip address, it depends on what you need.
Also here is the documentation:
http://www.scribd.com/doc/4191119/hp-laserjet-8150-users-manual-guide
there is an option for search, you can look for IP Address (I guess that;s what you mean by ip, am I right)
Good Luck.
Apr 25, 2009 | HP LaserJet 8150 Printer
50.1 Fuser Error on our HP 8150
You should replace the whole LVPS and not just the voltage regulator.
Jun 10, 2008 | HP LaserJet 8150 Printer
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
HP LaserJet 8150n Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
