After changing tascam 32 capstan belt my tape still don't works
The capstan motor seems to work without the belt, when I put the belt in position it doesn't work at all. I can rewind and FFW but can't play.
robotek
  • 1512 Answers
SOURCE: capstan belt
Hi
What make and model are you repairing?
robotek
Posted on Jul 27, 2008
Grubhead
  • 5190 Answers
SOURCE: belt change for Teac a4010sl reel to reel
You can but try! However either make a drawing of how the thing fits together or better still take pictures if you have a digital camera. Then you will know how it fitted together.
Posted on Mar 23, 2009
SOURCE: Transport door stuck, suspect tape wound about capstan.
Open the unit and try to turn the capstan whell with a tip to release the heads and the door locks.
Posted on Apr 25, 2009
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
  • 9 Answers
SOURCE: I have TEAC A 4010. Motors are running, belts are
Ensure the rubber pinch roller presses the tape against the capstan drive shaft....ensure the capstan drive motor is turning..and the belt to the flywheel is snug, and not slipping. the tape transport engage relay might be stuck...a relay maybe corroded ...may need cleaning. Without seeing it cant say clearly what may be the problem. also ensure the tape tension/shut-off arm is under tension by tape that is correctly installed.
Posted on Jun 08, 2010
I have a Tascam 688 mini studio, its 8 tracks on a cassette tape, I have just replaced the capstan belt and now the tape speed is way too fast even when I'm in variable mode with the speed turned all the...
It is possible the control transistor in the capstan motor has shorted due to age. There is a control in the deck for calibration of speed but then you need equipment and a MXT111 test tape to set the speed. So you may need a new Capstan motor or maybe just an adjustment- hard to say exactly without me looking at it- yes, I still fix them. I have been doing them for about 45 years and I worked at Teac as a Lead Tech in Arlington Heights IL.
Mar 13, 2015 | Tascam Audio Players & Recorders
Tascam 22 2
There are many places if you look to find belts. MCM sold some, PRB, Ken's Electronics in MI, Then there is Marrs. Consolidated has a lot of great belts at the right price but they may not be thick enough.
The belts are both change by taking off the front panel and all the knobs and getting to the mechanism in this way. The counter belt is easy the Capstan Belt more difficult as you need to unmount the head block- do not mess with head adjustment screws. The belt is slipped under the Flywheel and threaded onto the motor pulley. After you put the belt in and it works well the speed adjustment is next. This is done with a speed alignment tape and frequency counter or wow and flutter meter for both speeds. The adjustment is two blue pots on the capstan servo board on the left side of the deck. The metal cover must be off. Head alignment will not be affected unless you play around with head screws. The head base assembly can be detached without alignment issues as I have done it many times. Of course Technicians go through the alignment procedure before returning the deck most times.
I do and I was a Teac Lead Technician and still do repairs now.
Apr 07, 2014 | Teac Audio Players & Recorders
Capstans
You probably need a new belt as well and the lubrication of the capstan bearings come from extracting the flywheels from the unit when the belt is changed. Then oil is put into those bearings and the new belt will make a big difference. The capstan motor should also have oil added to the top bearing. After this a speed calibration will be needed. I have worked on hundreds of cassettes of every different brand so I am familiar with what they need.
Feb 17, 2014 | Audio Players & Recorders
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
Need capstan belt for reel to reel -tascam-dx-44,pls help.
The model is not a DX44 as that is a dBx unit attached to either a Tascam 44 or 40-4. The tape deck model would need to be determined and when that is done go to Marrs Communications and order the belt kit for that machine and you will get the capstan and counter belt.
http://marrscommunications.com/tascam-cassette-kits
Oct 09, 2010 | Tascam Audio Players & Recorders
I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Dec 03, 2009 | Tascam Audio Players & Recorders
Mar 08, 2009 | Tascam 202MKIII Single Dual Cassette Deck
Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Mar 21, 2008 | Tascam Audio Players & Recorders
47 people viewed this question
 Grubhead
Grubhead
