Question about Garden
Removing drive v belt pulley from my wheel horse c-120 12 hp kohler engine
  • 133 Answers
SOURCE: I need a drive belt diagram for a 1974 john deere
I don't have a diagram but it shouldn't be to hard. You will have to drop the deck. Then when installing the new belt remember to always place the inside of the belt (V) into the pulleys and the outside of the belt (flat side) up against the larger idler pulley. When you have the belt on properly it should be snug. If you have excessive play you need to try a different routing around the idler.
Good luck and let me know if this helps.
Thanks
roundo4
Posted on Sep 06, 2009
  • 8404 Answers
SOURCE: howdo you belt pulley from the engine shaft on a
I have not looked up your model to see if I can find an answer.
I think if I were faced with this problem, I would try to stretch the belt over the pulley before I tried to remove the pulley. I have tried both ways and stretching is superior to removing the pulley every time. I say so because you are going to have to get that darn pulley back on the shaft afterward and the belt will fight you every MM of the way. Plus you will be working in a confined space --- looking up --- in the dark --- on your back!
short out the plugs so the motor cannot fire -or at least disconnect them. Get the edge of the belt in the groove of the pulley then **** fingers out of the way **** turn the pulley around. The belt should go right on.
Let me know how you do.
thanks
Posted on Sep 07, 2009
mickey813
  • 472 Answers
SOURCE: I am trying to install a v belt ground drive on my
YOU WILL NEED TO DROP THE STACK PULEY DOWN AND MAKE SURE THE PARK BREAK IS SET THAT MAKES THE BELT LOOSE
Posted on Sep 30, 2009
harlan301
  • 205 Answers
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Posted on Oct 11, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
Having trouble removing drive belt
Remove belt from opposite end so you don't fight with clutch end.
Jul 02, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
How do I put the wheel drive belt back on the pulleys?
Feed onto engine pulley, remove front drive pulley by removing scews holding plastic cover over drive pulley, feed over drive pulley.
Apr 25, 2015 | Honda HRX217VKA Lawnmower
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
What all has to be removed to get the starter off of a Kohler M12 engine on a wheel horse tractor
Just like a chevy pu, two bolts in back and one in front.
To remove strap.
Aug 21, 2012 | Garden
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
What is the easyist way to change belt on older troybilt horse tiller without pulling motor
You dont need to pull the motor ... in fact if you do , that will not help you. We are talking about a genuine Troy, right? Bujilt in Troy not Cleveland.
At most, you will have to remove th reverse disk.
Take off the off the old belt(s) (mine 6 hp Horse is a older two belt drive). You must be in neutral. Pull the belt off the back of the engine pulley and down to give you slace to get it off the transmission pulley then pull it away.
It is very easy to say and a llittle harder to do but not as hard as you think, believe me. I have 2 belts and have replaced them several times.
YOU CAN DO IT>
Oct 08, 2009 | Troy-Bilt Pony Garden Tiller
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
