Question about Kenmore 94499 Refrigerator
Fridge filling with water
Our refridgerator is always full of water. Under the crisper drawers, on the shelves, in the drawers, on the floor. I have seen water pouring out of the area where the cold air comes from. Help, I'm tired of my food getting ruined.
  • jgwilliams84 Jul 15, 2008
    i think my drain is clogged but dont know how to clean it out tryed using a clothes hangger but still wont drain
  • Anonymous Mar 19, 2014
    refridgerator has water on shelves and under the bottom bins
  • 661 Answers
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Posted on Oct 09, 2007
  • Gareth Cockram
    Gareth Cockram Oct 09, 2007
    also I would reccomend checking your door seals as it sounds like something may be blocking a seal from closing properly letting kitchen air (full of water) into your fridge making all the water in the first place
SOURCE:
Whirlpool refridgerator leaking water all over fridge drawer, bottom of crisper drawers and shelves. It sounds like it may bed the freezer drain. Is that on the outside of the freezer or inside?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 17, 2011 | Refrigerators
The refrigerator always gets water in the base under the crisper drawers and on the shelves. How do I stop it from doing this?
There are two reasons. One check defrost is working properly. And second defrost tray has no crack.
and also while inserting defrost tray 100% pushed in.
Jan 22, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
Water is collecting under the crisper drawers and on the the shelves
The fridge has a blocked drain...water from defrost cycle not able to get to drain pan. Remove rear panel in freezer and look at bottom....will probably have is built up at drain hole.....use a cup of water to clear until in runs down drain.(may need to check drain pan afterwards to see how full it is)
Jun 08, 2009 | Kenmore Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Kenmore 94499 Refrigerator Logo
489 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
