Question about EAR POLLUTION EarPollution CS40 Headphones, Black
I recently bought Ear Pollution over the head headphones and they just stopped working for no reason
Not sure if the product listed is correct. I use my headphones every day, but they are taken care of. The cord does not get bent more than expected, but all of a sudden, the right head phone went out. Then, while trying to get it to work (spinning the jack) the left went out and now it won't work at all. I've had these for maybe a month.
  • 2,113 Answers
It sounds like you have a break in the wires. They make the wires stranded and they are finer than hair but will break if bent back and forth enough or if pulled on hard enough
Posted on Nov 21, 2013
How can I repair my Beats Mixr headphone in which one of the ear is not working ?
Presumably this is a wiring problem, for one of two reasons. If you look at the RCA plug that you use to hook into your stereo, you will see two black bands on it - one band for each signal - left or right. If there isn't a good connection, often you won't get sound in both earpieces. First try inserting the plug into your equipment part way, or rotating it carefully, to see if you can get both ears working. If that doesn't work, then the problem is either the wire for whatever ear is not working, not being connected properly at the RCA plug itself, or at the ear in question. You can unscrew the plastic cover on the RCA plug to see the wiring connection. But if the connection is bad at the actual earpiece, I would suggest returning the headphones, rather than taking them apart. Good luck.
May 23, 2014 | Beats By Dr Dre MIXR Black Over-Ear...
My right earbud stopped working and ive had the product for less than 2 months... all the wiring looks fine and no physical damage is noticeable
Unfortunately the ear buds are not made to be repaired, your best option is take them back for replacement "hopefully they are under warranty"
Mar 03, 2011 | Skull Candy LINK Earbuds Consumer...
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
I need new ear pads for my Aiwa HP-CN5 headphones.Is there a source for these?
I hunted around. No luck. Then I stopped in an found the perfect fit from of all places Radio Shack. The Earpads come with a smaller pair and you have to buy both but they are an excellent replacement. The Radio Shack replacements are #330-0288 - Replacement Headphone Earpads - $6.99 USD.
Oct 26, 2009 | Aiwa HP-CN5 Headphones
Cut cord on sony MDR XD100 head phones
Check out my blog that contains information on headphone cable problems.
Real Life And Real Charts
Oct 14, 2017 | Sennheiser HDR 120 Consumer Headphones
Only One Ear Works!?!?!?
get on there site and warranty them. they will replace them for you. www.skullcandy.com/warranty
Jul 08, 2008 | Skull Candy Ink'd Stereo Ear Bud...
No left ear sound.
That happened to me. It is fixable, but you need to open the caseing of the mp3 player itself. what hapened was that one of the dongles connecting the jack to the main chipset lost connection. you probably bent the headphone thing too much and it released.
to open the sansa, you must take out the battery. then you should find 2 black screws near the edge of the casing. Unscrew them and take off the black plastic cover. You should see the bottom is now totally silver. Near the headphone jack there should be another screw, Unscrew it. These are the only screwes you will need to unscrew from now. Next, Pry off the screen cover to reveal the chipset. Remove the connection from the chipset to the button pad. Take a standard screwdriver and carefully pry out the chipset, revealing the headphone jack. Be sure that the 3 dongles hooking it up to the chipset are in place. Put some tape on however you like, just be sure its tight, and be sure it doesnt interfere with any of the side buttons. Then add some more tape underneith the dongle for more support (do this unless you have a sodder, then sodder the dongles back on. Put the chipset back in the casing and replace the faceplate (dont forget to connect the button pad back to the chipset), and replace the back thing. Put the battery back in and test it. If it doesnt work then add a little tin foil into the back on the dongle. It should work.
Nov 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
EAR POLLUTION EarPollution CS40 Headphones, Black Logo
66 people viewed this question
Top EAR POLLUTION Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an EAR POLLUTION Audio Player and Recorder Expert? Answer questions, earn points and help others
