Question about Vehicle Parts & Accessories
Astrostart My vehicle only starts when I am about 50 feet away,,not even
    Novelist:
    Scholar:
  • 86 Answers
Check the battery in your remote, it may be getting weak.
Also AUTOSTART claims that the 1000FT is based on line of sight, unobstructed testing in ideal conditions. Actual range will vary due to local conditions including but not limited to environment, terrain, physical obstructions, vehicle location and orientation, interference and other possible impediments.
Try driving out to a place that is flat and open in all directions. Walk up to 1000 feet away, and try every 100ft as you walk back to see when it will start.
If you have a building, wall, or other object between your remote and the vehicle the signal may not be reaching the antenna on the vehicle.
Posted on Dec 01, 2013
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Nov 24, 2015 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Astrostart hst5224
What's the year make and model of the truck
Jul 14, 2014 | Vehicle Parts & Accessories
Netgear65 n750 not effective 40 ft. away
If the router has "N" value it should run a good distance away, even to the neighbors home. If "G" 30 Feet to 50 feet max.
40 Feet is difficult if passing through thick walls or steel buildings. If it is not an "N" router, then you need that or an Extender system. See TigerDirect for hardware replaements.
Apr 15, 2014 | NetGear WGR614 Wireless Router
Astrostart and brakelights dont work
electrical problem. wires are crossed
Mar 07, 2014 | Vehicle Parts & Accessories
Astrostart troubleshooting
try in boot / trunk compartment, or behind the kick panels in the front foot wells and up under the dash board
Dec 24, 2013 | Vehicle Parts & Accessories
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
Vehicle Parts & Accessories Logo
87 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
