Question about Home
Need a rubber seal can't find EPC-807
Typed in model # can find results even one that I can use that is compatible with my model
2 Suggested Answers
  • 29 Answers
SOURCE: Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Posted on Jun 30, 2010
Peugeot 807 faults
cheap china batteries, or duracell.
huh?
if good battery makes.
then the fob is bad, buy a new fob.
yes, the can go bad, seen many do this.
even got wet, ?
i buy the rubber covers for mine so they stay dry. (good uses of china parts, a cover) only use IMO.
May 25, 2014 | 2007 Peugeot 807 2.0
Instructions
Here is the manual 8Qt Digital Pressure Cooker Pressure Cookers Elite Platinum MAXI MATIC...
It is down at the bottom center of the page "Download" kind of hard to see
Mar 04, 2014 | Maximatic Maxi-Matic - Elite Platinum...
Audi epc light
What ,year audi and model? EPC LIGHT PO299. let me see if i can find out with out year and model.
okay, if your car has turbo then this is correct, po299 low boost.
this may be caused by a bad diverter valve on the turbo, if you remove it and look ay diaphram for any cracks or splits in rubber, if it is then replace it ,check for an update valve at dealer.
there are other thing that can cause this code but start with that. a loose hose for the turbo can cause this code or bad turbo or clogged converter, or oil sulge problem.
Jun 29, 2013 | Cars & Trucks
I need an instruction book for the Elite Platinum Electric Pressure Cooker Model # EPC807
This was pretty hard to find, but I located it just for you!
Here it is, you will need adobe reader to view it, but you most likely have that already, if not get it from get.adobe.com/reader/:
http://micromatikal.dlinkddns.com:8000/cust/EPC-807.pdf
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 22, 2010 | Kitchen Appliances - Others
My 2003 monte carlo ls has drag to it when switching gears or shuld i say late reaction when swithching gears it takes longer then i think it shuld i dono wats rong
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST.
Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout.
Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace. Also replace the boost valve and EPC filter screen and worst, replace the EPC valve when you service the transmission.
Thank you for using fixya and Try not to run or drive the car to hard or further damage could result.
May 10, 2010 | 2003 Chevrolet Monte Carlo
Chain
Yes All motorcycle chains currently being manufactured use Buna-N (Nitrile) rubber for their o-rings and x-rings and all these manufacturers recommend kerosene as a cleaner. Here's the formulation of WD-40: 80% Stoddard Solvent (that is similar to kerosene) 20% light lubricating oil and a bit of fragrance. Here's the compatibility of Stoddard Solvent with rubbers and plastics: Good Compatibility (OK for both static and dynamic seals) Buna-N (Nitrile) Chemraz Epichlorohydrin Fluorocarbon Fluorosilicone Kalrez Nitrile, hydrogenated Polyacrylate Teflon, virgin Mixed Compatibility (OK for static seals, but not for dynamic seals) Neoprene Vamac Fair Compatibility (OK for some static seals) Polysulfide Polyurethane, millable Poor Compatibility Butyl Ethylene-Propylene Hypalon Natural rubber Silicone Styrene Butadiene Consequently, WD-40 is safe and effective as a chain cleaner and corrosion inhibitor. Link: http://www.efunda.com/designstandard...dard%20Solvent If you clean with a soft brush and WD-40, and plan to follow-up with a chain lube, you can reduce chain lube sling-off if you first remove the oil residue that WD-40 leaves. This residue seems to prevent some chain lube formulations from sticking well to the chain.,,,
Nov 10, 2008 | 2004 Skyteam ST 125 TR
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
