Heater not workin
Cold n winter hot n summer
    Problem Solver:
  • 17 Answers
Move, to a different place or even different state/country. If there is nothing you can do about it, learn to deal with it but no matter what you do, do not whine about it because no one gives a rat's a...
Posted on Nov 22, 2013
Ford 302
Make sure the cooling system is not plugged up, poor coolant flow can make your engine run hot, and a plugged heater core will not allow heat in the cabin in the winter.
Aug 10, 2014 | 1990 Ford F150
Tankless water heater doesn't produce hot water in the winter when tempetures are below 32 degrees. I tried a water saver shower head and this worked for a little while. Anything else I can do ?
1) Tempering tank might help:
http://waterheatertimer.org/Tempering-tank.html
2) Reduce temperature setting on tankless unit so there is less differential between incoming cold water and thermostat set point.
3) Absolutely any tankless problem can be solved same day by installing tank-type gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
4) Add comment and say what you do to solve problem.
Jan 31, 2013 | Bosch AquaStar 2400ES-NG
My boiler heating is working but hot water is not coming. i want to know how to set hot water 24 hours 7 days
As I understand your question, you have a boiler with a 'summer/winter' hookup for domestic hot water.
Your boiler should run all the time, i.e. not be shut off by you. Your boiler provides hot water for baseboard heat in your home ... possibly through several 'zones' each controlled by an individual thermostat and circulator. Yours may be a steam system. If this is the case, you have radiators not radiant baseboard heaters and no circulators.
Your summer/winter hookup provides a constant supply of domestic hot water. It does this by taking cold water from your water main and passing it through a copper coil which sits inside your boiler and then to your hot water main in your home. Since the coil sits in the hot water at the top of the boiler, it is constantly being heated. This coil may be in a deteriorated condition in your case or it may be too small for your needs.
Several years ago, I did a small upgrade to my mid 1950's era American Standard boiler. The summer winter hookup in my case was mounted on a 4 inch cast iron boiler plug. The coil was 12 feet long (folded up to a package about 1 foot long). I was very afraid when the plumber came in with what amounted to a 10 foot long pipe wrench. My fear was I would have a pile of broken cast iron at the end of the day. All is well that ends well. He got the old one out and replaced it with a coil that consisted of 20 feet of copper tubing 3/4 inch in size (the folded tubing was about 20 inches long and fit nicely into the boiler). We now have all the hot water a household consisting of one guy and three gals would need in all but the extremest of times..
I think you r answer is here ... replace your summer/winter coil with a new, bigger coil.
Something else I did. My kitchen is 60 feet (pipe wise) from the boiler. It takes a long time to get hot water there. I put in a small electric hot water heater just under the kitchen. I put a timer on it so it runs for a couple hours in the morning and a few hours in the afternoon. The hot water line from the boiler serves as the cold water input to the heater. I now enjoy the convenience of quick hot water in the kitchen with the relatively low cost of oil heated water from the boiler as a relatively small cost of electricity.
My winter settings are 160 - 200 and my summer settings are 120 - 150 which seems adequate for our needs.
Thanks for your question at FixYa.com. I hope I have been of assistance to you today.
Feb 05, 2011 | Heating & Cooling
The heater in a 1996 cadillac fleetwood does not blow hot air when engine is idling, it is just warm, when the weather is very cold, (below 25 degrees.) when it is not this cold it seems to work...
I am guessing you have not changed your thermostat from a summer one to a winter one. If this is the case you need to put a 195 degree thermostat in to replace the 165 degree summer one. Let me know. Thanks.
Jan 22, 2011 | 1996 Cadillac Fleetwood
What is the recommended tyre pressure for winter conditions
the same as during the summer. look on your tires and test the pressure to see if it's close to the maximum psi, they are good, refill if the pressure is troo low.
the air is compressed when it's cold and expands as it gets hot. check your tire pressure every week and especially when the temperature changes like the cold winters and the hot summer.
Jan 21, 2011 | 2000 Jeep Grand Cherokee
We had a new air codititioner compressor put on last summer now that winter is here heater dont work I temp, control from cold to hot no change . Is there something they may have not hook up ....it was...
The damper door is located on the passenger side, next to the floor board. You can look in and see the door, kind of under the center console, under the dash. This door controls whether the Jeep blows hot or cold air.
Jan 03, 2011 | 1998 Jeep Wrangler
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Water when having a shower goes cold in winter but warm in summer why is this? please help
That is because the water temperature of the water going into the hot water heater is warmer in the summer so it is not as difficult to make e nough hot water..
heatman101
Jul 01, 2010 | Home
My 1997 ford f150 heater blows cold air in winter and hot air in
first check and see if it has a thermstat installed or stuck open, second, make sure that your heater has not been bypassed by connecting the two hoses together
Apr 12, 2009 | 1997 Ford F150 Regular Cab
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
