Question about Stihl HT101 Pole pruner
Chain will not spin - Stihl HT101 Pole pruner
Chain will spin when I put clutch and bar back together start it up chain spins then stops and clutch gets red hot?
or a to thick chain or the chain was not cleaned after use before a long time The chain may be stiff with tree resin, you have the chain anyway can rotate by hand when the machine is not on the safety brake
Jan 30, 2016 | Garden
How much oil to add?
fill bar oil allow for small amount of expansion from heat of bar and chain, but to get hot the chain must spin, and when the chain spins oil is used, just dont let it run out.
Sep 17, 2013 | Earthwise Yt4729 12-inch 9 Amp Electric...
Chain won,t spin
Hello. When the chain won't spin, loosen the tension a bit and put some bar and chain oil directly on the chain and bar. Joe
Sep 18, 2010 | Echo Garden
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Jul 12, 2010 | Makita DCS640120 Commercial Grade 20Inch...
Engine starts blade won't spin
The large black plastic bar sticking up is a kick back safety device. Pull it back toward the handle to make sure it has not been engaged. If it is engaged the chain will not move. If that is not the problem then the chain clutch is defective. I am assuming the chain is not too tight.
Apr 25, 2010 | Husqvarna Chain Saw 20" Bar
McMulloch EM250 motor spins but the chain does not move
your problem is a simple one. the chain is too tight. loosen the two nuts that hold the bar in place and use a flat blade screw driber to turn the tension screw a wee bit to loosen the chain just a little. finally spray some wd-40 or other lube on the bar and chain and you will be fine.
Jun 29, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Saw is running, but chain is not moving
If you rev the engine and the chain does not spin, either the chain is jammed, or is adjusted to tightly on the bar, or the centrifugal clutch is malfunctioning. With the engine off and leather gloves on, see if the chain will move on the bar, you should be able to move the chain 4 or 5 inches. If you can spin it, the clutch is probably bad. If its stuck, take the housing off over the clutch and make sure the chain is seated on the sprocket and not jammed to the side. Inspect the chain on the bar, there should some slight play in the chain tension. Look for any links that dont flex. This happens to be cause I overtighten the chain to the bar.
Dec 22, 2008 | Homelite Garden
Stihl HT101 Pole pruner Logo
169 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
