Question about Maytag MEDC200XW Dryer
My matag dryer will not heat
I have the maytgag MEDC200xw1 dryer sometimes the element comes on and then shuts off for no reason. replaced the thermo fuse,high limit thermostat and cut off switch, and it will not heat up. And the heating element is good. what else could it be, the timer?
SOURCE: Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Posted on Apr 25, 2009
bruce508
  • 44 Answers
SOURCE: Dryer heats then stops heating.
If the cleaning helped before, maybe something is still clogged. Check particularly the area around the lint filter. Take it out and see if you can remove lots of lint, maybe with something like a coat hanger and a bit of skill and care. I have found air passages to lint filters crammed, particularly when people have neglected cleaning the filter.
Sometimes, if the room is dark and you look the right place (like maybe the back panel grill), it is easy to see the light of the coils turning off and on. Sometimes that behavior can provide a clue.
Posted on Jun 29, 2009
  • 177 Answers
SOURCE: how do I test my dryers heating element, and High
Both can be checked with a multimeter set to the ohms setting. Disconnect the coil from the dryer and place a test lead to one end og the coil. Place the other test lead on the opposite end of the coil. If the circuit closes, the coil is good. Do the same with the High Limit thermostat. If the thermostat is closed, the thermostat is good. (Note: that is if the thermostat is Normally Closed - opens when the temperature exceeds the temperature). You can find out by contacting the replacement parts center.
Posted on Aug 04, 2009
localwonder
  • 6784 Answers
SOURCE: Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Posted on Aug 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Posted on Apr 10, 2010
Kenwood KCD1W tumble dryer not heating up replaced element and all three stats still not getting hot ?
Check main cable connections and power from main circuit. Possible one leg is open because of circuit breaker defective, open circuit from breaker through connection on the back of the drier. Sometimes the connector internal at the power connection will fail (see second image).
Check Thermo-fuse. If this thermo-fuse fails it will need to be replaced. (see first image).
If only one leg that supplies 120 volts is powered then motor and controls can operate. the heater elements are the part of the dryer that requires the other leg for the 240.
Hope this helps?
Nov 29, 2016 | Dryers
My centennial dryer MEDC200XW1 wont start.
Hello;
My name is Peter. I am a retired field service appliance technician.
There are several reasons your dryer will not start.
1.) Bad door switch?
2.) Plugged up with lint?
3.) Thermal fuse?
a.) On the back of your dryer is a hot air distribution manifold. It is easily un-bolted to remove. In the bottom of this manifold dryers get plugged up with lint. If you have a air flow problem your unit will shut down.
Your unit will also not run if you have a bad door switch.
But, here is where I am going to put my money on as your problem.
High limit thermostat on your heater element in the back of your unit.
  • The thermostat is functional to 221 degrees (Fahrenheit).
  • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
This High-Limit Thermostat part #3977767 Cost: $15.00
You can replace this part yourself.
Get back to me if this does not solve you problem. You cab jump the door switch.
Feb 16, 2015 | Maytag Centennial Series MEDC200XW
Maytag dryer wont heat
Probably the timer. Remove the quick connect from the timer where the big red wire is that comes off the heating element. Check that leg with the leg next to it. moving the timer knob . You should get a meter reading. If you cannot get a read then that timer is fried inside. I did a video which shows one exactly like yours.
Nov 21, 2013 | Maytag MEDC200XW Dryer
I have a roper rex5634kq1 the heater shorted and i replaced it but the thermo cut out is stopping it from getting 230 volts is the thermo cut out normally closed or normally open this one had no...
normally closed on any thermal cutout this is to make the circuit to operate the dryer till it overheats,then the thermal opens to shut off current to the heating element for safety
Sep 10, 2011 | Roper RES7646KQ Electric Dryer
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
Dryer is over heating, all thermo have been replaced along with motor and belt. Turn on and still shuts down and smells like its burning. Dryer is hot to touch.
dryer element is fused to metal housing thereby heating all the time as the element is grounded all the time making a closed circuit
Apr 17, 2009 | Maytag MMV4205 Microwave Oven
Dryer runs foe a while 10 min. the it shuts off.
sounds as if you hav a bad motor assy, its tripping off on an overheat thermo and resetting when cools off, replace the motr assy
Nov 13, 2008 | Speed Queen AES28AWF Electric Dryer
Kenmore 110.66712690 66712 ser.#mf3411314 not heating
ck the thermo fuse on the lint duck inside dryer its the white one also ck the thermo fuse on the element housing the one near the back dryer
Mar 06, 2008 | Dryers
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MEDC200XW Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
